Hi.
How to correct this code? (I get “unknown” value)
mqtt:
- name: "mo_bagno_test_illuminance"
state_topic: "zigbee2mqtt/mo_bagno"
value_template: "{{ value_json.illuminance }}"
Home Assistant OS (on Rasp) - Broker Mosquitto - Z2Mqtt
petro
(Petro)
2
The topic is most likely not zigbee2mqtt/mo_bagno
. You need to use MQTT explorer or some similar software to figure out the actual topic.
Your topic is most likely going to be
homeassistant/<some_unique_id>/<domain>/
francisp
(Francis)
3
Make sure your state topic is correct (case sensitive!)
# - name: "Frontdoor"
# state_topic: "sensor/frontdoor"
state_topic: "zigbee2mqtt/Eetkamer"
Be sure to wait until a new mqtt message is received.
Sorry… this code is right.
I just had to wait for the sensor to update (set previously every 60’)…
mqtt:
