I have a device connected via zigbee2mqtt and I would like to get a value from it to use in an automation. No matter what I do I don’t appear to be able to read it. When I look in the zigbee2mqtt section for the device I see that it exposes a lot:
When I go to the state tab I have the following:
"last_seen": 1696758210466,
"linkquality": 184,
"local_temperature_heat": 21.71,
"local_temperature_water": 21,
"occupied_heating_setpoint_heat": 1,
"occupied_heating_setpoint_water": 22,
"running_state_heat": "idle",
"running_state_water": "heat",
"system_mode_heat": "off",
"system_mode_water": "emergency_heating",
"temperature_setpoint_hold_duration_heat": 0,
"temperature_setpoint_hold_duration_water": 0,
"temperature_setpoint_hold_heat": false,
"temperature_setpoint_hold_water": true,
"weekly_schedule_water": {
"days": [
"saturday"
"transitions": [
"heating_setpoint": 99,
"time": 330
"heating_setpoint": 0,
"time": 510
"time": 720
"time": 840
"time": 1020
"time": 1200
How can I for example get system_mode_water into an automation?
