I’ve a automation to turn off my water heating if the forecast cloud coverage is below a defined amount. (The necessary value I’m testing)
It seems to run properly but I get no value of the n_cloud_coverage in the message. So I’m also unsure, if the condition triggers in the way I want:
alias: 09:56 Brenner OFF
description: Brenner OFF wenn Aussentemp > 8°C und Vorhersage Bewölkung < 90%
triggers:
- at: "09:56:00"
trigger: time
conditions:
- condition: numeric_state
entity_id: sensor.temp_keller_aussen_temperature
above: 8
actions:
- target:
entity_id: weather.forecast_home
type: hourly
response_variable: forecast_data
action: weather.get_forecasts
- if:
- condition: template
value_template: >
{% set n_cloud_coverage =
forecast_data['weather.forecast_home'].forecast[6].cloud_coverage %}
{{ n_cloud_coverage < 95 }}
then:
- target:
entity_id: 9d4d20356e7b640809d4a0f09c63e54f
data: {}
action: switch.turn_off
- metadata: {}
message: Brenner AUS (Vorhersage Bewölkung 14 Uhr {{ n_cloud_coverage }})
action: notify.matrix_notify
mode: single
Can somebody give me a hint or see a misstake?
10der
(Oleg Denisenko)
April 12, 2025, 9:54am
2
hi!
before you starts to develop automation, always play with services what you plan to use in http://homeassistant.local:8123/developer-tools/action
also i can recommend you use http://homeassistant.local:8123/developer-tools/template
and final sandbox after you starts to develop automation
so, as you can see, not issues with n_cloud_coverage
be sure what at 09:56:00 items number 6 is present in weather response
be sure what your weather provider support cloud_coverage
That variable does not have a value in the notification action because it is outside its scope. There are a couple ways to solve this… I would define the variable more globally by using a Script variable:
triggers:
- at: "09:56:00"
trigger: time
conditions:
above: 8
actions:
- target:
type: hourly
- variables:
n_cloud_coverage: "{{ forecast_data['weather.forecast_home'].forecast[6].cloud_coverage }}"
- if:
value_template: "{{ n_cloud_coverage < 95 }}"
then:
- action: switch.turn_off
data: {}
- action: notify.matrix_notify
metadata: {}
mode: single
Thank you, that’s it!
I had suspected something like this, but didn’t know how to solve it.
