Hello everyone,
I am trying to get the state of my webcam into home assistant. As a cam I am using a raspberry pi zero with a Pi HQ module. The pi is running a firmware that makes it took to the PC as a regular webcam.
One pin on the pi gets HIGH when the webcam is active and I use this as the input for a gpio binary sensor. Documentation of webcam firmware
For esphome I am using a wemos D1 mini with a ESP8266.
I have now connected the 5V and GND of the Pi with the d1 mini and the webcam pin to D4 on the d1 mini.
The good news: it works, although it needed some delay for debouncing and when the pin on the pi goes back to low, the blue LED on the d1 mini stays lit. When the pin on the pi goes high again, the LED goes off. It seems to me that there might be some current flowing where it is not supposed to be.
My question as a electronics noob: do I need some pullup or pulldown resistors? I just connected the pins of the D1 mini and the rpi directly. Do I need a resistor between these two pins?
Thanks for your help!
