I’m trying to create morning weather briefing, I started from creating template sensors. Problem is that only part of them works. Does anyone have idea why?
Below is code I use, only first 2 works (temperatura maksymalna and temperatura minimalna) the rest create sensor, but state is “unknown”.
- trigger: #temperatura maksymalna
- trigger: time_pattern
hours: /1
minutes: "/1"
- action: weather.get_forecasts
type: daily
entity_id: weather.forecast_home
response_variable: daily
- name: Temp max prog
unique_id: temp_max_prog
state: "{{ daily['weather.forecast_home'].forecast[0].temperature }}"
unit_of_measurement: °C
- trigger: #temperatura minimalna
hours: /1
minutes: "/1"
type: daily
- name: Temp min prog
unique_id: temp_min_prog
state: "{{daily['weather.forecast_home'].forecast[0].templow}}"
- trigger: #predkosc wiatru
hours: /1
minutes: "/1"
type: daily
- name: predkosc wiatru prog
unique_id: predkosc_wiatru_prog
state: “{{daily['weather.forecast_home'].forecast[0].wind_gust_speed}}”
unit_of_measurement: m/s
- trigger: #prawdopodobienstwo opadow
hours: /1
minutes: "/1"
type: daily
- name: opad prawdopodobienstwo
unique_id: opad_prawdopodobienstwo
state: “{{daily['weather.forecast_home'].forecast[0].precipitation_probability}}”
- trigger: #opad
hours: /1
minutes: "/1"
type: daily
- name: opad prog
unique_id: opad_prog
state: “{{daily['weather.forecast_home'].forecast[0].precipitation}}”
unit_of_measurement: mm
- trigger: #wilgotnosc
hours: /1
minutes: "/1"
type: daily
- name: wilgotnosc prog
unique_id: wilgotnosc_prog
state: “{{daily['weather.forecast_home'].forecast[0].humidity}}”
