I have found and figured out how to ‘convert’ a list of for instance sensors into a list of their friendly names, but Zones do hot have an entity_id attribute. I have been struggling with templates to figure out a solution, but am not having any luck.
1: So given a list of zones like you would get using a zone selector, how can I generate a list of the zones’ friendly_name(s). I need those because that is the actual value of the person entity and I want to see if the person is in one of the zones in a list.
2: I don’t think this is possible, but as a random thought if I could use the zones friendly name as reported by the person entity and connect that back to the actual zone entity, I could make that work as well.
3: As a fallback I could compare the persons attribute in the zone to see if it has person. Just thought of that one, haven’t tried it yet. (update, won’t work, logic is wrong)
Anyhow I bet there is a way to do that first one and would like to know if anyone has found it.
Of course none of this would be necessary if I could solve my first pass at all this. I can’t get the zone selector and the zone trigger to talk to each other…
The following is working as a script. I haven’t messed with Blueprints much… so not 100% sure it will work there.
alias: Test zone field friendly
fields:
zones:
description: The zones
selector:
entity:
domain: zone
multiple: true
sequence:
- service: persistent_notification.create
message: >
{% set ns = namespace(zone=[]) %}
{% for z in zones %}
{% set ns.zone = ns.zone + [states[z].attributes.friendly_name] %}
{% endfor %}
{{ ns.zone }}
mode: single
