I have a power meter (SDM230), giving me 15 entities. One of these (Active Power) I have displayed as a Gauge in a Dashboard.
Disappointingly, although I know (by watching meter display) that in reality, the power is “dancing around” in response to cooking demands and solar excess, the Gauge display reports that it has not changed/updated for long periods of time?
I note multiple postings with the advice that using “force_update” is very (very) bad! So not tried that yet. If “force_update” were to produce the effect I’m looking for, would it be so bad if it were only for display and not logged to the Home Assistant database?
Should I be able to achieve “near real-time” updates from my SDM230 sensor to the Dashboard Graph display?
INFO Reading configuration /config/esphome/esp32-sdm230m.yaml...
INFO Starting log output from esp32-sdm230m.local using esphome API
INFO Successfully connected to esp32-sdm230m.local
[18:49:23][I][app:102]: ESPHome version 2023.5.2 compiled on May 22 2023, 08:36:32
[18:49:23][C][wifi:505]: WiFi:
[18:49:23][C][wifi:363]: Local MAC: EC:62:60:9D:B3:48
[18:49:23][C][wifi:364]: SSID: 'myAP1'[redacted]
[18:49:23][C][wifi:365]: IP Address: 192.168.0.136
[18:49:23][C][wifi:367]: BSSID: 44:E9:DD:6E:71:6C[redacted]
[18:49:23][C][wifi:368]: Hostname: 'esp32-sdm230m'
[18:49:23][C][wifi:370]: Signal strength: -58 dB ▂▄▆█
[18:49:23][V][wifi:372]: Priority: 0.0
[18:49:23][C][wifi:374]: Channel: 6
[18:49:23][C][wifi:375]: Subnet: 255.255.255.0
[18:49:23][C][wifi:376]: Gateway: 192.168.0.1
[18:49:23][C][wifi:377]: DNS1: 192.168.0.1
[18:49:23][C][wifi:378]: DNS2: 0.0.0.0
[18:49:23][C][logger:301]: Logger:
[18:49:23][C][logger:302]: Level: VERBOSE
[18:49:23][C][logger:303]: Log Baud Rate: 0
[18:49:23][C][logger:305]: Hardware UART: UART0
[18:49:23][C][uart.arduino_esp32:124]: UART Bus 0:
[18:49:23][C][uart.arduino_esp32:125]: TX Pin: GPIO16
[18:49:23][C][uart.arduino_esp32:126]: RX Pin: GPIO17
[18:49:23][C][uart.arduino_esp32:128]: RX Buffer Size: 256
[18:49:23][C][uart.arduino_esp32:130]: Baud Rate: 9600 baud
[18:49:23][C][uart.arduino_esp32:131]: Data Bits: 8
[18:49:23][C][uart.arduino_esp32:132]: Parity: NONE
[18:49:23][C][uart.arduino_esp32:133]: Stop bits: 1
[18:49:23][C][modbus:143]: Modbus:
[18:49:23][C][modbus:145]: Send Wait Time: 250 ms
[18:49:23][C][modbus:146]: CRC Disabled: NO
[18:49:23][C][modbus_controller:275]: ModbusController:
[18:49:23][C][modbus_controller:276]: Address: 0x01
[18:49:23][C][modbus_controller:278]: sensormap
[18:49:23][C][modbus_controller:284]: ranges
[18:49:23][C][sdm_meter:087]: SDM Meter:
[18:49:23][C][sdm_meter:088]: Address: 0x01
[18:49:23][C][sdm_meter:093]: Phase A
[18:49:23][C][sdm_meter:094]: Voltage 'ESP32.SDM230M Voltage'
[18:49:23][C][sdm_meter:094]: Device Class: 'voltage'
[18:49:23][C][sdm_meter:094]: State Class: 'measurement'
[18:49:23][C][sdm_meter:094]: Unit of Measurement: 'V'
[18:49:23][C][sdm_meter:094]: Accuracy Decimals: 2
[18:49:23][C][sdm_meter:095]: Current 'ESP32.SDM230M Current'
[18:49:23][C][sdm_meter:095]: Device Class: 'current'
[18:49:23][C][sdm_meter:095]: State Class: 'measurement'
[18:49:23][C][sdm_meter:095]: Unit of Measurement: 'A'
[18:49:23][C][sdm_meter:095]: Accuracy Decimals: 3
[18:49:23][C][sdm_meter:096]: Active Power 'ESP32.SDM230M Active Power (P)'
[18:49:23][C][sdm_meter:096]: Device Class: 'power'
[18:49:23][C][sdm_meter:096]: State Class: 'measurement'
[18:49:23][C][restart:068]: Restart Switch 'ESP32_SDM230m Restart'
[18:49:23][C][restart:070]: Icon: 'mdi:restart'
[18:49:23][C][restart:091]: Restore Mode: always OFF
[18:49:23][C][mdns:108]: mDNS:
[18:49:23][C][mdns:109]: Hostname: esp32-sdm230m
[18:49:23][V][mdns:110]: Services:
[18:49:23][V][mdns:112]: - _esphomelib, _tcp, 6053
[18:49:23][V][mdns:114]: TXT: version = 2023.5.2
[18:49:23][V][mdns:114]: TXT: mac = ec62609db348
[18:49:23][V][mdns:114]: TXT: platform = ESP32
[18:49:23][V][mdns:114]: TXT: board = esp32doit-devkit-v1
[18:49:23][V][mdns:114]: TXT: network = wifi
[18:49:23][C][ota:093]: Over-The-Air Updates:
[18:49:23][C][ota:094]: Address: esp32-sdm230m.local:3232
[18:49:23][C][ota:097]: Using Password.
>>>>>>>[18:49:23][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8)
[18:49:23][C][api:138]: API Server:
[18:49:23][C][api:139]: Address: esp32-sdm230m.local:6053
[18:49:23][C][api:143]: Using noise encryption: NO
[18:49:24][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:49:24][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:49:24][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:49:24][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:49:24][V][modbus:042]: Modbus received Byte 106 (0X6a)
[18:49:24][V][modbus:042]: Modbus received Byte 178 (0Xb2)
[18:49:24][V][modbus:042]: Modbus received Byte 60 (0X3c)
[18:49:24][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:49:24][V][modbus:042]: Modbus received Byte 64 (0X40)
[18:49:32][V][modbus_controller:158]: Updating modbus component
>>>>>[18:49:33][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8) # last modbus write was 18:49:23]
[18:49:34][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:49:34][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:49:34][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:49:34][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:49:34][V][modbus:042]: Modbus received Byte 107 (0X6b)
[18:49:34][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:49:34][V][modbus:042]: Modbus received Byte 163 (0Xa3)
[18:49:34][V][modbus:042]: Modbus received Byte 64 (0X40)
[18:49:42][V][modbus_controller:158]: Updating modbus component
>>>>>[18:49:43][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8) # Last modbus write was [18:49:33]
[18:49:44][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:49:44][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:49:44][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:49:44][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:49:44][V][modbus:042]: Modbus received Byte 107 (0X6b)
[18:49:44][V][modbus:042]: Modbus received Byte 32 (0X20)
[18:49:44][V][modbus:042]: Modbus received Byte 31 (0X1f)
[18:49:44][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:49:44][V][modbus:042]: Modbus received Byte 63 (0X3f)
[18:49:44][V][modbus:042]: Modbus received Byte 244 (0Xf4)
**[18:49:44][D][sensor:094]: 'ESP32.SDM230M Export Active Energy': Sending state 909.06403 kWh with 2 decimals of accuracy**
>>>>>>>[18:49:52][V][modbus_controller:158]: Updating modbus component # last modbus write was [18:49:43]
[18:49:53][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8)
[18:49:54][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:49:54][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:49:54][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:49:54][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:49:54][V][modbus:042]: Modbus received Byte 106 (0X6a)
[18:49:54][V][modbus:042]: Modbus received Byte 241 (0Xf1)
[18:49:54][V][modbus:042]: Modbus received Byte 45 (0X2d)
[18:49:54][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:49:54][V][modbus:042]: Modbus received Byte 63 (0X3f)
[18:50:02][V][modbus_controller:158]: Updating modbus component
[18:50:03][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8)
[18:50:04][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:50:04][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:50:04][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:50:04][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:50:04][V][modbus:042]: Modbus received Byte 106 (0X6a)
[18:50:04][V][modbus:042]: Modbus received Byte 163 (0Xa3)
[18:50:04][V][modbus:042]: Modbus received Byte 187 (0Xbb)
[18:50:04][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:50:04][V][modbus:042]: Modbus received Byte 63 (0X3f)
[18:50:12][V][modbus_controller:158]: Updating modbus component
[18:50:13][V][modbus:199]: Modbus write: 01.04.00.00.00.50.F0.36 (8)
[18:50:14][V][modbus:042]: Modbus received Byte 1 (0X1)
[18:50:14][V][modbus:042]: Modbus received Byte 4 (0X4)
[18:50:14][V][modbus:042]: Modbus received Byte 160 (0Xa0)
[18:50:14][V][modbus:042]: Modbus received Byte 67 (0X43)
[18:50:14][V][modbus:042]: Modbus received Byte 106 (0X6a)
[18:50:14][V][modbus:042]: Modbus received Byte 177 (0Xb1)
[18:50:14][V][modbus:042]: Modbus received Byte 203 (0Xcb)
[18:50:14][V][modbus:042]: Modbus received Byte 0 (0X0)
[18:50:14][V][modbus:042]: Modbus received Byte 63 (0X3f)
So, as I read it, the UART/Modbus write/read traffic is every 10 seconds. But although some the values returned are differing from the previous read, the only sensor that was sent to Home Assistant during this sample run was for “Export Active Energy” at [18:49:44].
Regards, M.
PS - Although, I think I have 15 entities defined in the yaml, only 4 are listed in the log pre-amble. Is this normal?
I have done a hardware replacement - with no change.
Any suggestion on how I can raise a question with the sdm_meter platform maintainer?
Had a hunt around, but the nearest I can find says “Do not post here”?
Regards, M.
