@firstof9, Apologies… Noob to HA here…
I think I figured out the mqtt.dump service.
OpenZWave/1/node/2/,{ "NodeID": 2, "NodeQueryStage": "Complete", "isListening": true, "isFlirs": false, "isBeaming": true, "isRouting": true, "isSecurityv1": false, "isZWavePlus": true, "isNIFRecieved": true, "isAwake": true, "isFailed": false, "MetaData": { "OZWInfoURL": "", "ZWAProductURL": "", "ProductPic": "", "Description": "", "ProductManualURL": "", "ProductPageURL": "", "InclusionHelp": "", "ExclusionHelp": "", "ResetHelp": "", "WakeupHelp": "", "ProductSupportURL": "", "Frequency": "", "Name": "", "ProductPicBase64": "" }, "Event": "nodeQueriesComplete", "TimeStamp": 1603965868, "NodeManufacturerName": "AEON Labs", "NodeProductName": "ZW096 Smart Switch 6", "NodeBasicString": "Routing Slave", "NodeBasic": 4, "NodeGenericString": "Binary Switch", "NodeGeneric": 16, "NodeSpecificString": "Binary Power Switch", "NodeSpecific": 1, "NodeManufacturerID": "0x0086", "NodeProductType": "0x0203", "NodeProductID": "0x0060", "NodeBaudRate": 100000, "NodeVersion": 4, "NodeName": "", "NodeLocation": "", "NodeGroups": 2, "NodeDeviceTypeString": "On/Off Power Switch", "NodeDeviceType": 1792, "NodeRole": 5, "NodeRoleString": "Always On Slave", "NodePlusType": 0, "NodePlusTypeString": "Z-Wave+ node"}
OpenZWave/1/node/2/instance/1/,{ "Instance": 1, "TimeStamp": 1603965864}
OpenZWave/1/node/2/instance/1/commandclass/112/,{ "Instance": 1, "CommandClassId": 112, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "CommandClassVersion": 1, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/844424973910036/,{ "Label": "Current Overload Protection", "Value": { "List": [ { "Value": 0, "Label": "Deactivate Overload Protection" }, { "Value": 1, "Label": "Active Overload Protection (Default)" } ], "Selected": "Active Overload Protection (Default)", "Selected_id": 1 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 1, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 3, "Node": 2, "Genre": "Config", "Help": "Load will be closed when the Current overruns (US 15.5A, Others 16.2) for more than 2 minutes", "ValueIDKey": 844424973910036, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/5629499577991188/,{ "Label": "Output Load Status", "Value": { "List": [ { "Value": 0, "Label": "Last status (Default)" }, { "Value": 1, "Label": "Always on" }, { "Value": 2, "Label": "Always off" } ], "Selected": "Last status (Default)", "Selected_id": 0 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 2, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 20, "Node": 2, "Genre": "Config", "Help": "Configure the output load status after re-power on.", "ValueIDKey": 5629499577991188, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/5910974554701844/,{ "Label": "RGB Led Color for Testing", "Value": { "List": [ { "Value": 1, "Label": "Reserved" }, { "Value": 2, "Label": "Red" }, { "Value": 3, "Label": "Green" }, { "Value": 4, "Label": "Blue" } ], "Selected": "Reserved", "Selected_id": 1 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 1, "Max": 4, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 21, "Node": 2, "Genre": "Config", "Help": "Configure the RGB Led Color for Testing", "ValueIDKey": 5910974554701844, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/22517998180630548/,{ "Label": "Notification status", "Value": { "List": [ { "Value": 0, "Label": "Nothing (Default)" }, { "Value": 1, "Label": "Hail" }, { "Value": 2, "Label": "Basic" } ], "Selected": "Nothing (Default)", "Selected_id": 0 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 2, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 80, "Node": 2, "Genre": "Config", "Help": "Defines the automated status notification of an associated device when status changes", "ValueIDKey": 22517998180630548, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/22799473157341204/,{ "Label": "Configure the state of the LED", "Value": { "List": [ { "Value": 0, "Label": "The LED will follow the status (on/off) of its load. (Default)" }, { "Value": 1, "Label": "When the state of the Switch changes, the LED will follow the status (on/off) of its load, but the LED will turn off after 5 seconds." }, { "Value": 2, "Label": "Night Light Mode" } ], "Selected": "The LED will follow the status (on/off) of its load. (Default)", "Selected_id": 0 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 1, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 81, "Node": 2, "Genre": "Config", "Help": "", "ValueIDKey": 22799473157341204, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/23362423110762515/,{ "Label": "Night Light Color", "Value": 14524637, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 16777215, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 83, "Node": 2, "Genre": "Config", "Help": "Configure the RGB Value when in Night Light Mode. Byte 1: Red Color Byte 2: Green Color Byte 3: Blue Color", "ValueIDKey": 23362423110762515, "ReadOnly": true, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/23643898087473171/,{ "Label": "RGB Brightness in Energy Mode", "Value": 5263440, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 16777215, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 84, "Node": 2, "Genre": "Config", "Help": "Configure the brightness level of RGB LED (0%-100%) when it is in Energy Mode/momentary indicate mode. Byte 1: Red Color Byte 2: Green Color Byte 3: Blue Color", "ValueIDKey": 23643898087473171, "ReadOnly": true, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/25332747947737104/,{ "Label": "Enables/disables parameter 91/92", "Value": false, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Bool", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 90, "Node": 2, "Genre": "Config", "Help": "Enable/disable Wattage threshold and percent.", "ValueIDKey": 25332747947737104, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/25614222924447766/,{ "Label": "Minimum Change to send Report (Watt)", "Value": 25, "Units": "watts", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 32000, "Type": "Short", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 91, "Node": 2, "Genre": "Config", "Help": "The value represents the minimum change in wattage for a Report to be sent (default 25 W)", "ValueIDKey": 25614222924447766, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/25895697901158417/,{ "Label": "Minimum Change to send Report (%)", "Value": 5, "Units": "%", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 100, "Type": "Byte", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 92, "Node": 2, "Genre": "Config", "Help": "The value represents the minimum percentage change in wattage for a Report to be sent (Default 5)", "ValueIDKey": 25895697901158417, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/28147497714843672/,{ "Label": "Default Group Reports", "Value": false, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Button", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 100, "Node": 2, "Genre": "Config", "Help": "Set report types for groups 1, 2 and 3 to default.", "ValueIDKey": 28147497714843672, "ReadOnly": false, "WriteOnly": true, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/28428972691554323/,{ "Label": "Report type sent in Reporting Group 1", "Value": 0, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": -2147483648, "Max": 2147483647, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 101, "Node": 2, "Genre": "Config", "Help": "Defines the type of report sent for reporting group 1. 2 is multisensor report. 4 is meter report for watts. 8 is meter report for kilowatts. Value 1 (msb) Reserved Value 2 Reserved Value 3 Reserved Value 4 (lsb) bits 7-4 reserved bit 3 KWH bit 2 Watt bit 1 Current bit 0 Voltage", "ValueIDKey": 28428972691554323, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/28710447668264979/,{ "Label": "Report type sent in Reporting Group 2", "Value": 0, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": -2147483648, "Max": 2147483647, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 102, "Node": 2, "Genre": "Config", "Help": "Defines the type of report sent for reporting group 1. 2 is multisensor report. 4 is meter report for watts. 8 is meter report for kilowatts. Value 1 (msb) Reserved Value 2 Reserved Value 3 Reserved Value 4 (lsb) bits 7-4 reserved bit 3 KWH bit 2 Watt bit 1 Current bit 0 Voltage", "ValueIDKey": 28710447668264979, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/28991922644975635/,{ "Label": "Report type sent in Reporting Group 3", "Value": 0, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": -2147483648, "Max": 2147483647, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 103, "Node": 2, "Genre": "Config", "Help": "Defines the type of report sent for reporting group 1. 2 is multisensor report. 4 is meter report for watts. 8 is meter report for kilowatts. Value 1 (msb) Reserved Value 2 Reserved Value 3 Reserved Value 4 (lsb) bits 7-4 reserved bit 3 KWH bit 2 Watt bit 1 Current bit 0 Voltage", "ValueIDKey": 28991922644975635, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/30962247481950232/,{ "Label": "Set 111 to 113 to default", "Value": false, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Button", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 110, "Node": 2, "Genre": "Config", "Help": "Set time interval for sending reports for groups 1, 2 and 3 to default.", "ValueIDKey": 30962247481950232, "ReadOnly": false, "WriteOnly": true, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/31243722458660883/,{ "Label": "Send Interval for Reporting Group 1", "Value": 3, "Units": "seconds", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": -1, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 111, "Node": 2, "Genre": "Config", "Help": "Defines the time interval when the defined report for group 1 is sent.", "ValueIDKey": 31243722458660883, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/31525197435371539/,{ "Label": "Send Interval for Reporting Group 2", "Value": 600, "Units": "seconds", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": -1, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 112, "Node": 2, "Genre": "Config", "Help": "Defines the time interval when the defined report for group 2 is sent.", "ValueIDKey": 31525197435371539, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/31806672412082195/,{ "Label": "Send Interval for Reporting Group 3", "Value": 600, "Units": "seconds", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": -1, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 113, "Node": 2, "Genre": "Config", "Help": "Defines the time interval when the defined report for group 3 is sent.", "ValueIDKey": 31806672412082195, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/56294995385909268/,{ "Label": "Partner ID", "Value": { "List": [ { "Value": 0, "Label": "Aeon Labs Standard (Default)" }, { "Value": 1, "Label": "Others" } ], "Selected": "Aeon Labs Standard (Default)", "Selected_id": 0 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 1, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 200, "Node": 2, "Genre": "Config", "Help": "Partner ID", "ValueIDKey": 56294995385909268, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/70931694174863380/,{ "Label": "Configuration Locked", "Value": { "List": [ { "Value": 0, "Label": "Disable" }, { "Value": 1, "Label": "Enable" } ], "Selected": "Disable", "Selected_id": 0 }, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 1, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 252, "Node": 2, "Genre": "Config", "Help": "Enable/disable Configuration Locked", "ValueIDKey": 70931694174863380, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/71494644128284694/,{ "Label": "Device tag", "Value": 0, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 65535, "Type": "Short", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 254, "Node": 2, "Genre": "Config", "Help": "Device tag.", "ValueIDKey": 71494644128284694, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/112/value/71776119104995352/,{ "Label": "Reset device", "Value": false, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Button", "Instance": 1, "CommandClass": "COMMAND_CLASS_CONFIGURATION", "Index": 255, "Node": 2, "Genre": "Config", "Help": "Reset to the default configuration.", "ValueIDKey": 71776119104995352, "ReadOnly": false, "WriteOnly": true, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/37/,{ "Instance": 1, "CommandClassId": 37, "CommandClass": "COMMAND_CLASS_SWITCH_BINARY", "CommandClassVersion": 1, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/37/value/38354960/,{ "Label": "Switch", "Value": true, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Bool", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_BINARY", "Index": 0, "Node": 2, "Genre": "User", "Help": "Turn On/Off Device", "ValueIDKey": 38354960, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965866}
OpenZWave/1/node/2/instance/1/commandclass/38/,{ "Instance": 1, "CommandClassId": 38, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "CommandClassVersion": 2, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/38/value/1407374930313235/,{ "Label": "Dimming Duration", "Value": 15300, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": -2147483648, "Max": 2147483647, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 5, "Node": 2, "Genre": "System", "Help": "Duration taken when changing the Level of a Device (Values above 15240 use the devices default duration)", "ValueIDKey": 1407374930313235, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/38/value/38371345/,{ "Label": "Level", "Value": 99, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 255, "Type": "Byte", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 0, "Node": 2, "Genre": "User", "Help": "The Current Level of the Device", "ValueIDKey": 38371345, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965866}
OpenZWave/1/node/2/instance/1/commandclass/38/value/281475015082008/,{ "Label": "Bright", "Value": false, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Button", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 1, "Node": 2, "Genre": "User", "Help": "Increase the Brightness of the Device", "ValueIDKey": 281475015082008, "ReadOnly": false, "WriteOnly": true, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/38/value/562949991792664/,{ "Label": "Dim", "Value": false, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Button", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 2, "Node": 2, "Genre": "User", "Help": "Decrease the Brightness of the Device", "ValueIDKey": 562949991792664, "ReadOnly": false, "WriteOnly": true, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/38/value/844424976891920/,{ "Label": "Ignore Start Level", "Value": true, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "Bool", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 3, "Node": 2, "Genre": "System", "Help": "Ignore the Start Level of the Device when increasing/decreasing brightness", "ValueIDKey": 844424976891920, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/38/value/1125899953602577/,{ "Label": "Start Level", "Value": 0, "Units": "", "ValueSet": false, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 255, "Type": "Byte", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_MULTILEVEL", "Index": 4, "Node": 2, "Genre": "System", "Help": "Start Level when Changing the Brightness of a Device", "ValueIDKey": 1125899953602577, "ReadOnly": false, "WriteOnly": false, "Event": "valueAdded", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/39/,{ "Instance": 1, "CommandClassId": 39, "CommandClass": "COMMAND_CLASS_SWITCH_ALL", "CommandClassVersion": 1, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/39/value/46776340/,{ "Label": "Switch All", "Value": { "List": [ { "Value": 0, "Label": "Disabled" }, { "Value": 1, "Label": "Off Enabled" }, { "Value": 2, "Label": "On Enabled" }, { "Value": 255, "Label": "On and Off Enabled" } ], "Selected": "On and Off Enabled", "Selected_id": 255 }, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_SWITCH_ALL", "Index": 0, "Node": 2, "Genre": "System", "Help": "Switch All Devices On/Off", "ValueIDKey": 46776340, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965865}
OpenZWave/1/node/2/instance/1/commandclass/51/,{ "Instance": 1, "CommandClassId": 51, "CommandClass": "COMMAND_CLASS_COLOR", "CommandClassVersion": 1, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/51/value/562950000394259/,{ "Label": "Color Channels", "Value": 28, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": -2147483648, "Max": 2147483647, "Type": "Int", "Instance": 1, "CommandClass": "COMMAND_CLASS_COLOR", "Index": 2, "Node": 2, "Genre": "System", "Help": "Color Capabilities of the device", "ValueIDKey": 562950000394259, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/51/value/38584343/,{ "Label": "Color", "Value": "#00FF00", "Units": "#RRGGBB", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "String", "Instance": 1, "CommandClass": "COMMAND_CLASS_COLOR", "Index": 0, "Node": 2, "Genre": "User", "Help": "Color (in RGB format)", "ValueIDKey": 38584343, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965868}
OpenZWave/1/node/2/instance/1/commandclass/51/value/281475015294996/,{ "Label": "Color Index", "Value": { "List": [ { "Value": 0, "Label": "Off" }, { "Value": 1, "Label": "Cool White" }, { "Value": 2, "Label": "Warm White" }, { "Value": 3, "Label": "Red" }, { "Value": 4, "Label": "Lime" }, { "Value": 5, "Label": "Blue" }, { "Value": 6, "Label": "Yellow" }, { "Value": 7, "Label": "Cyan" }, { "Value": 8, "Label": "Magenta" }, { "Value": 9, "Label": "Silver" }, { "Value": 10, "Label": "Gray" }, { "Value": 11, "Label": "Maroon" }, { "Value": 12, "Label": "Olive" }, { "Value": 13, "Label": "Green" }, { "Value": 14, "Label": "Purple" }, { "Value": 15, "Label": "Teal" }, { "Value": 16, "Label": "Navy" }, { "Value": 17, "Label": "Custom" } ], "Selected": "Lime", "Selected_id": 4 }, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 0, "Type": "List", "Instance": 1, "CommandClass": "COMMAND_CLASS_COLOR", "Index": 1, "Node": 2, "Genre": "User", "Help": "Preset Color", "ValueIDKey": 281475015294996, "ReadOnly": false, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965868}
OpenZWave/1/node/2/instance/1/commandclass/94/,{ "Instance": 1, "CommandClassId": 94, "CommandClass": "COMMAND_CLASS_ZWAVEPLUS_INFO", "CommandClassVersion": 1, "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/94/value/47677457/,{ "Label": "ZWave+ Version", "Value": 1, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": 0, "Max": 255, "Type": "Byte", "Instance": 1, "CommandClass": "COMMAND_CLASS_ZWAVEPLUS_INFO", "Index": 0, "Node": 2, "Genre": "System", "Help": "ZWave+ Version Supported on the Device", "ValueIDKey": 47677457, "ReadOnly": true, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/94/value/281475024388118/,{ "Label": "InstallerIcon", "Value": 1792, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": -32768, "Max": 32767, "Type": "Short", "Instance": 1, "CommandClass": "COMMAND_CLASS_ZWAVEPLUS_INFO", "Index": 1, "Node": 2, "Genre": "System", "Help": "Icon File to use for the Installer Application", "ValueIDKey": 281475024388118, "ReadOnly": true, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/94/value/562950001098774/,{ "Label": "UserIcon", "Value": 1792, "Units": "", "ValueSet": true, "ValuePolled": false, "ChangeVerified": false, "Min": -32768, "Max": 32767, "Type": "Short", "Instance": 1, "CommandClass": "COMMAND_CLASS_ZWAVEPLUS_INFO", "Index": 2, "Node": 2, "Genre": "System", "Help": "Icon File to use for the User Application", "ValueIDKey": 562950001098774, "ReadOnly": true, "WriteOnly": false, "Event": "valueChanged", "TimeStamp": 1603965863}
OpenZWave/1/node/2/instance/1/commandclass/114/,{ "Instance": 1, "CommandClassId": 114, "CommandClass": "COMMAND_CLASS_MANUFACTURER_SPECIFIC", "CommandClassVersion": 2, "TimeStamp": 1603965864}
OpenZWave/1/node/2/association/1/,{ "Name": "LifeLine", "Help": "", "MaxAssociations": 5, "Members": [ "1.0" ], "TimeStamp": 1603965864}
OpenZWave/1/node/2/association/2/,{ "Name": "Retransmit Switch CC", "Help": "", "MaxAssociations": 5, "Members": [], "TimeStamp": 1603965865}
(snipped a few lines off the bottom to get it to fit in the post)
I can see
Night Light Color but it seems to be read only. I assume thats a problem.
I also see “OpenZWave/1/node/2/instance/1/commandclass/51/value/38584343/,{ “Label”: “Color””
Is that useable and can I update it from HA?
