I have the Alexa skill working through Nabu Casa. I have the automation exposed to Alexa (it shows as a “scene”), and it is definitely doing something with HomeAssistant, but it doesn’t actually trigger the automation.
In the logbook, it shows this: Amazon Alexa sent command Alexa.PowerController/TurnOn for Test Automation triggered by service automation.turn_on
I assume what’s happening is it’s not triggering the automation, but literally just “enabling” the automation (which it is already always enabled), and the automation does not actually run. I also assume I have to somehow find the event trigger (is that what it would be?) to listen for the command that is coming in from Alexa or something and use that as the trigger in the Automation?
Obviously the message is coming through, but I don’t know how to make it actually trigger the automation to run.
This is what it looks like in the Alexa app for the routine:
Automations are things that start automatically, scripts are basically the same as the action part of an automation, but are intended to be started by automations, other scripts, voice assistants, etc.
For anyone coming from Google, if you go to the Automations menu, look at the top and go to the “Scripts” tab.
Then I made a new one with an action to “Call Service”, then “Automation: Trigger”. Then I clicked “Choose Entity” and selected the automation I want to trigger. Then I set the Script to be exposed to Alexa, and it also showed up as a Scene. Adding it to an Alexa routine and activating it worked, and it triggered the Script which triggered the automation.
a bit of a necro, but if you have more than one thing triggering this automation, then it woujld make sense to do it the way @TJoe did unless i am missing something more subtlle here. At any rate, this is good enough for me for now.
