In older HA versions, it was possible to get all ZHA devices with
{{ states.zha|list }}
but it seems that the zha.* entities have been dropped in new HA versions.
Is there any other way to get the list of ZHA devices?
This is great question. I would like to know that as well.
No answer yet. I think it is not possible to get the list of devices any more, you can only get a list of entities with {{ states|list }}
What is the use case for this? There are web socket commands that return this…
Hi David, one usecase: an automation which regularly checks the battery state of zigbee devices. Another usecase: a reporting script generating a maintenance list of the zigbee devices.
Meanwhile I have 30 zigbee devices with battery, every few weeks a battery is empty and it needs a lot of time to find out why home assistant is not working like it should. without a good battery management and reporting my system is not very usable. I have been abroad for 2 months and after coming back, 3 devices did not work because the battery was empty. The house was cold because the temperature sensor did not work. If I had a chance to check the batteries every week, this would not happen.
I find this card to be a good way to stay ahead of any battery issues. Just check the card periodically for the battery levels.
This card needs a list of devices. I won’t type in a list. “states.zha” used to be exactly that list, but it stopped working.
Not if you use it in conjunction with the auto-entities card.
Here is my config:
- type: custom:auto-entities
card:
type: custom:battery-state-card
show_header_toggle: false
state_color: true
color_gradient:
- "#ff0000" # red
- "#ffff00" # yellow
- "#00ff00" # green
filter:
include:
- entity_id: 'sensor.*_battery_level'
show_empty: false
sort:
method: state
numeric: true
I never add any battery devices to any list. As long as they end in “_battery_level” (which almost everything should now unless it’s custom - but you can even change that too) they will automatically populate in the list.
