Getting an error with a script
Here’s a script in scripts.yaml:
script:
  button_test:
    alias: Button
    sequence:
      - service: mqtt.publish
            topic: ToggleDoor2
            payload: '1'
      - delay: 00:00:03
      - service: door_1.turn_off
script:
  do_nothing:
I borrowed it from another post and modified it slightly. Here’s one error:
2019-09-21 06:24:11 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: script
When I flip the switch, I get
Failed to call service switch/turn_on unable to find service script/button_test
See file
All I want to do is have a push button that publishes a topic. Surely it can’t be hard, but I can’t find the answer. I’ve tried at least 6 different suggested ways of doing it and nothing works. Please help.
Thanks,
Jim.
Screenshot%20at%202019-09-21%2006-40-17
Here’s the entry in configuration.yaml that calls it:
switch:
    switches:
      door_1:
        value_template: "{{ false }}"
        turn_on:
          service: script.button_test
            entity_id: '1569002528159'
        turn_off:
          service: script.do_nothing
Your scripts.yaml should look like this (without the script: keys)
button_test:
  alias: Button
  sequence:
          topic: ToggleDoor2
          payload: '1'
    - delay: 00:00:03
do_nothing:
But it still won’t work because your service after the delay is not valid.
Thanks, all I want to do after the delay is reset the switch display to the off position. How can I do that? This is supposed to be a simple push button, rather than an on/off switch.
Jim
What’s the entity id of the thing you want to turn off?
It doesn’t have one
I gave up on the scripts. I can’t believe that a simple push button would be so hard.
Here’s what I have currently:
switch:
    - platform: mqtt
      command_topic: "Door1"
      payload_on: '1'
      payload_off: '1'
      optimistic: true
    - platform: mqtt
      command_topic: "Door2"
      payload_on: '1'
      payload_off: '1'
      optimistic: true
I’m not happy about the look of it, but it works. It’s way too busy.
Screenshot%20at%202019-09-23%2004-58-12
Something like this.
Screenshot%20at%202019-09-23%2005-02-53
So the payloads for on and off are the same? Why wouldn’t this work?
button_test:
  alias: Button
  sequence:
        topic: Door2
        payload: '1'
    - delay: 00:00:03
        topic: Door1
        payload: '1'
Other than it looks like it would close/open both doors at once, I don’t know. I’ll try it.
That works. It takes up a whole lot more real estate than it should but I can live with it. The designer of this UI must be a reincarnated COBOL programmer. :smile:
Thanks!
Jim.
