Hey People.
After playing around with my FreePBX and This Project I finally present a way to get calls for certain events like I leave the house and let some lights on (Which is normally impossible as they should turn off when I leave the house. But this is only an example how you can receive calls from Home-Assistant.
I know this project is still in beta but already ready-to-use state, I want to present my setup:
In this guide, I will show you how to setup a service call that can call a SIP endpoint, say something and hangup.
Requirements
For this guide you will need the following:
- Googletts
- Preinstalled in the add-on
- If your not using the add-on, you can install it here.
- Asterisk integration installed
Dialplan (FreePBX [extensions_custom.conf
] / HassIO-Addon [ extensions.conf
First, let’s make a dialplan extension.
[speech] ; The context
exten => 123,1,Answer() ; Answer the call
exten => 123,n,agi(googletts.agi,"${TEXT}",en) ; Execute the googletts agi script with the TEXT variable
Service
service: asterisk.originate
channel: PJSIP/100 # The device it will call
context: speech # The context we created in the dialplan
exten: '123' # The extension inside that context
priority: '1' # Priority of the call
caller_id: 'Home Assistant' # The callerID it calls as
timeout: 60 # Time until giving up
variables: TEXT: Hello world! # Variables that you can use in the dialplan
Example: Get a call if doors or windows are still open or if lights are still on when you leave the house
For this to work you simply have to create a group with all window and door / lights entities in your house.
Add to extensions.conf
(HassIO-Addon) / or extensions_custom.conf
(FreePBX)
[home-assistant-lights] ; The context
exten => 123,n,agi(googletts.agi,"${LIGHTS}",en) ; Execute the googletts agi script with the LIGHTS variable
[home-assistant-windows-doors] ; The context
exten => 123,n,agi(googletts.agi,"${WINDOWDOOR}",en) ; Execute the googletts agi script with the WINDOWDOOR variable
After you can make service calls like this:
channel: SIP/8002
context: home-assistant-windows-doors
exten: '123'
priority: '1'
caller_id: Home Assistant
timeout: 60
variables:
WINDOWDOOR: "Attention. The following doors or windows are still open: {{ dict((states|selectattr('entity_id', 'in', state_attr('group.windows_doors', 'entity_id'))|list)|groupby('state'))['on']|map(attribute='name')|list|join('.......... ') }}"
Full automation Example:
Lights still turned on
- alias: sip - call if lights still on
platform: state
entity_id: group.persons
to: "not_home"
for: "00:00:03"
condition:
- condition: state
entity_id: group.windows_doors
state: "on"
- service: asterisk.originate
channel: SIP/8002
context: home-assistant-lights
exten: '123'
priority: '1'
caller_id: Home Assistant (Lights On)
timeout: 60
variables:
LIGHTS: "Attention. The following lights are still on: {{ dict((states|selectattr('entity_id', 'in', state_attr('group.lights_house', 'entity_id'))|list)|groupby('state'))['on']|map(attribute='name')|list|join(' ...... ') }}"
Open Windows and doors
- alias: sip - call if door or window is open
platform: state
to: "not_home"
for: "00:00:03"
condition:
- condition: state
state: "on"
channel: SIP/8002
exten: '123'
priority: '1'
caller_id: Home Assistant (Windows / Doors open)
timeout: 60
variables:
WINDOWDOOR: "Attention. The following Windows or Doors are still open: {{ dict((states|selectattr('entity_id', 'in', state_attr('group.windows_doors, 'entity_id'))|list)|groupby('state'))['on']|map(attribute='name')|list|join(' ...... ') }}"
