Getting climate control's target temparature
Hello everyone,
I have a problem about getting the climate control’s “target temperature”. I am getting current_temperature from the climate card but target_temperature showing itself as NAN. Here is my codes.
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXXXXXXXXXXXXXXXXXXXXXXXXXX"
ota:
  password: "XXXXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Thermostatoda Fallback Hotspot"
    password: "Ic9G710Rbkh4"
captive_portal:
  # Example configuration entry
dallas:
  - pin: 4
# Individual sensors
  - platform: dallas
    index: 0
    name: "Livingroom Temperature"
  - platform: rotary_encoder
    pin_a:
      number: 2
      inverted: true
      mode: INPUT_PULLUP
    pin_b:
      number: 12
      inverted: true
      mode: INPUT_PULLUP
    filters:
      - or:
        - debounce: 0.1s
        - delta: 10
    min_value: 5
    max_value: 30
    resolution: 2
    on_clockwise:
    - switch.turn_on: switch_lcdbacklight
    - logger.log: "Turned Clockwise"
    on_anticlockwise:
    - logger.log: "Turned Anticlockwise"
  - platform: homeassistant
    entity_id: climate.kombi_thermostat
    attribute: current_temperature
    attribute: target_temperature
output:
  - platform: gpio
    pin: 16
switch:
  - platform: output
    output: lcdbacklight
    on_turn_on:
    - delay: 5s
    - switch.turn_off: switch_lcdbacklight
binary_sensor:
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: false
    filters:
      - delayed_on: 10ms
    on_press:
      then:
        - logger.log: "Button pressed"
spi:
  clk_pin: 14
  mosi_pin: 13
font:
  - file: "gfonts://Bebas Neue"
display:
  - platform: st7920
    update_interval: 1s
    cs_pin:
      number: 15
      inverted: true
    width: 128
    height: 64
    lambda: |-
      it.image(4, 14, id(Home));
      it.image(7, 40, id(Thermometer));
      it.rectangle(0, 0, 127, 63);
      it.printf(22, 13, id(font_1), "%.1f°", id(current_temp).state);
      it.printf(22, 37, id(font_1), "%.1f°", id(target_temp).state);
image:
  - file: "images/Home_16x17.png"
  - file: "images/Thermometer2_16x17.png"
Thanks in advance…
The attribute you want is temperature not target_temperature.
The description on this page (Climate Component — ESPHome) states it as target_temperature, but actually it is just temperature as you said. I’ve been dealing with this for two days. Thank you so much. :pray:
Yes, but that is when setting up a esphome native climate component. You are importing a climate component from HA which uses temperature. If you need to see what attributes an entity has, look in developer tools.
Thank you for your advice…
