Running HA Supervised > Docker > Ubuntu[18.04.4 LTS] (installed using HA official docs as guidance). Was able to get a Zwave USB Stick working successfully, but no such luck with ConBee II.
The CB stick is not recognized using either the HA > supervisor > system > hardware, nor by running “sudo ha hardware info” from SSH CLI.
I’ve installed deCONZ. However it will not start. I’ve reviewed docs for HA deCONZ, and have made the following changes inside configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
discovery:
deconz:
host: 192.168.1.24
port: 80
Restarted the service. Rebooted the machine. No change. FYI, on reboot, I get this log message:
ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused
Next, go to Configurations > Integrations > Add New Integration > deCONZ Zigbee Gateway.
Add host IP Address: 192.168.1.24
Port: 80 (default)
Next popup states the following:
Link with deCONZ
Unlock your deCONZ gateway to register with Home Assistant.
Go to deCONZ Settings → Gateway → Advanced
Press “Authenticate app” button
Couldn’t get an API key
So, I’m stuck, where am I supposed to go from here? I’ve been out to Phoscon’s site, but didn’t find any clues their either.
I can only comment on the community container. Since you’re running HA with docker, I would recommend using the deCONZ container as well. I have both running on my ubuntu server and have no issues with them communicating.
Which begs the question. Why do I need to install/run Docker, since there are no other server level applications on this NUC? HA leads me to believe that there’s no other option when running Linux as an OS.
I believe you could install it with python. But I haven’t tried it myself. I’m a pretty big docker fan, so I’ve never tried any of the other installation methods.
On the other hand I run HA supervised as explained on that same page (way lower) in docker. And just installed deconz in the supervisor and followed the well written instructions in that addon to the letter. It works perfectly out of the box. So maybe you overlooked something while installing? Maybe remove everything you did and try over?
