Getting config validation automation error even with no automations
Upgraded from 85.1 to 86.3. Cannot pass config validation, now. Getting error:
Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See ?, line ?). Please check the docs at Automation - Home Assistant
I didn’t have a lot of automations as I use node red for 90% of things. None of my automations had minutes in the trigger as I have seen the time vs time_pattern issue. I ended up deleting every single automation in automations.yaml and I’m still getting the error. I’ve tried reloading automations, etc… I started with a blank automations.yaml and created a brand new automation using the HA automation wizard. Still get the error above.
I cannot reboot due to the config validation error. I could cold boot the rpi3+, but I hate to because that always screws up my zwave and zigbee2mqtt connections and takes forever to get the pi back recognizing those two usb sticks. However I will do that if that is what I’m advised to do.
Hopefully I’m just doing something stupid. Arggggggggh
Do you have/use packages?
Thank you, you just saved my sanity. I wasn’t sure if I had packages, but I checked and I have one for a battery_alert.yaml that was causing the issue. Thanks again.
