I would need some help getting data from my Temperature/Humidity device which can be displayed on a webpage. I thought it would be possible using scrape but have no clue where and how to start with.
Maybe somebody can help me with this, below I have a screenshot of the HTML content, I would like to get Temperature and Humidity, Airpressure is not needed.
Will be happy for a nice solution.
Not sure if this will work, but try right clicking on the row, where your temperature value is (13.9°C), then select Copy → Copy selector.
Paste that value to the sensor under “select” and that should do it. Repeat for humidity.
Smthg like this:
Beware, that this will be string, not a number, as the selected value (13.9°C) is a string, and you won’t be able to do further calculations or whatever.
Thanks for your answer, I have tried your config, but getting an error
Logger: homeassistant.components.rest.data
Source: components/rest/data.py:74
Integration: RESTful (documentation, issues)
First occurred: 12:02:33 (6 occurrences)
Last logged: 12:02:54
I have done what admiral posted above, but I am getting an error, so I thought this is probably the wrong approach. I am still not even sure if scrape is the proper way to get what I want.
I have also tried this config, but didn#t work either:
platform: scrape
resource: “http://192.168.1.1:86”
select: “td”
index: 8 #experiment with this number to find the correct value
value_template: ‘{{ ((value.split(" “)[0]) | replace (”,", “.”)) }}’
unit_of_measurement: “%”
platform: scrape
name: Air Pressure Cellar
select: “td”
I have put in a port forwarding, so you should be able to connect to the sensor using this link: http://192.168.1.1:86/smart
you could also use this link:
ok got it thanks,
I tried to copy the HTML code but can’t select and use copy in the window you see below. Sorry but I don’t know how to copy that content as text as I am not even available to select it in this window.
if (self!= top)
{ alert('Um diese Seite auf Ihrem Smartphone zu laden \ngeben Sie als URL http://ip-adresse/smart ein \n\nTo display this page on your Smart Phone,\nplease enter as URL http://ip-address/smart');
var password = '';
var interval = 5000;
var CommandString = new Array();
mval = ['','','','','','','',''];
mtag = ['<a href="info.htm?Ili=0&Ref=smart.htm?Vpos=39167&DTb=0&">Temperature Cellar</a>','<a href="info.htm?Ili=1&Ref=smart.htm?Vpos=39167&DTb=0&">Humidity Cellar</a>','<a href="info.htm?Ili=2&Ref=smart.htm?Vpos=39167&DTb=0&">Airpressure Cellar</a>','','','','',''];
var maxm = 0;
function Commandloop()
{ DataRequest(CommandString[0]);
maintimer = setTimeout("Commandloop()", interval);
function DataRequest(sendstring)
{ var xmlHttp = window.ActiveXObject ? new ActiveXObject("Microsoft.XMLHTTP") : xmlHttp = new XMLHttpRequest();
if (xmlHttp)
{ xmlHttp.onreadystatechange = function()
{ if (xmlHttp.readyState == 4)
{ if (xmlHttp.status == 200)
{ updateDisplay(xmlHttp.responseText)
xmlHttp=null;
xmlHttp.open("GET", sendstring, true);
xmlHttp.setRequestHeader("Connection", "close");
xmlHttp.setRequestHeader("If-Modified-Since", "Thu, 1 Jan 1970 00:00:00 GMT");
xmlHttp.send(null);
function updateDisplay(ReceiveString)
{ var ReceiveData = ReceiveString.split(";");
for (i=0;i<maxm;i++)
{ document.getElementById('mv'+i).innerHTML = ReceiveData[ReceiveData.length-maxm+i];
function createDisplay()
{ for (i=0;i<mtag.length;i++)
{ if (mtag[i]!='')
{ maxm++;
for (var i = 0; i < maxm; i++)
{ var singletag = mtag[i].split('>');
mtag[i] = singletag[1].substring(0, singletag[1].length - 3)
document.body.innerHTML+='<div class="ds" id="dn"> Cellar </div>';
for (i = 0; i < maxm; i++)
{ document.body.innerHTML += '<div class="ds">'+mtag[i]+'</div>';
document.body.innerHTML += '<div id="mv'+i+'" class="val iov">'+mval[i]+'</div>';
CommandString = ['single'];
Commandloop();
If that code block is the code then that is the issue.
If there is javascript in a webpage then a scrape tool won’t work since the values isn’t there but are placed there by JavaScript and that can’t be fetched with scrape tools.
