I am trying to create a sensor that extracts data from a URL. I know this is JSON data, but dont quite get how to process it, can someone give me some advice on this, the URL is
You could create a REST sensor that contains the three data points (current, cumulative, timestamp) instead of just the current level. And then extract them with a separate template sensor.
Sorry for crashing this thread hereā¦
Iām a absolute beginner with Home Assistant.
Could you give me some hints where to add this ārest sensorā.
I have a very similar case and like to read some data from a api url string (hope this description is correct) but my use case look very similar the the one explaned here in this threat.
I like to read all 6 variables from this url (like open, temp, etc).
Not sure if I have to use developer mode or to change any config file inside home assistant. Hope you could support me.
Thanks !
BR Matze
