Hello folks, I have two ecobees where they spit out temperature and humidity and I can track them in the history fine. Also using yo.no I am having my outdoor temperature and humidity added as a sensor. I am really interested in plotting the difference between the two temperatures. Any thoughts on how to do this either through influxdb and grafana or HA history/sensor component?
You could create a sensor that does simple math on the two other entities, then just simply graph that sensor.
Thanks, for the suggestion but I am relatively new to HA, how can I go about doing this?
Ahhā¦are you familiar at all with how templates work?
Not at all
Thatās where you need to start. Are you on HASS.io or a different version of Home Assistant? Whatās your environment look like?
I am running on NUC through virtual box. Be honest with you I even donāt have a single automation script everything goes through node red.
Iād use a template sensor and something like thisā¦just change the entities for your ecobee and outside temperature sensor.
indoor_outdoor_temp_diff:
entity_id:
- sensor.home_temperature
- sensor.dark_sky_apparent_temperature
value_template: >-
{% set ecobee = states.sensor.home_temperature.state|float %}
{% set outdoor = states.sensor.dark_sky_apparent_temperature.state| float %}
{{ outdoor - ecobee }}
Awesome, I will try it tonight. Thank you so much.
Thanks @Jer78 that was perfect for what I was looking for too. There was one line missing that I needed to add to my config in case anyone else comes across it. I also rounded down the float for readability.
sensors:
entity_id:
- sensor.living_room_temperature
value_template: >-
{% set esphome = states.sensor.living_room_temperature.state|float %}
{{ (outdoor - esphome)|round(1) }}
Sorry for the thread hijack but I have the same question. The following works in the template tool (in developer tools) but is failing when I do a āha core checkā.
Any ideas?
- alias: Rumpus Light Left On
platform: state
entity_id: binary_sensor.motion_sensor_158d0002b84fd3
to: 'off'
condition:
- condition: template
value_template: {{ states('sensor.illumination_158d0002b84fd3') | float > ( states('sensor.wupws_solarradiation') | float / 0.0079 ) }}
- service: notify.gav_bullet
data_template:
message: "Light might be left on"
Sorry, do you mean āconfiguration checkā ?
Can you post the error you get ?
Edit: No, my blindness, single line templates require (double, in this case) quotes.
So : -
value_template: "{{ states('sensor.illumination_158d0002b84fd3') | float > ( states('sensor.wupws_solarradiation') | float / 0.0079 ) }}"
Though you should get away with : -
value_template: "{{ states('sensor.illumination_158d0002b84fd3') | float > states('sensor.wupws_solarradiation') | float / 0.0079 }}"
Thanks @Mutt that was it!
I use this template sensor which does work, however if I look at the value of the sensor it just sayās active. I want to see the value in degrees however. The goal is to create an automation that triggers if the temperature difference between two rooms is hoger than 2 degrees a blower switches on which blows the warmer air from the hottest room to the other colder room.
I use this YAML code:
# Calculated Value Sensor
# Temperature difference between Magazijn en Entree
sensors:
magazijn_entree_temp_diff:
entity_id:
- sensor.temp_magazijn_temperature
- sensor.temp_entreeruimte_temperature
value_template: >-
{set magazijntemp = states.sensor.temp_magazijn_temperature.state| float }
{set entreetemp = states.sensor.temp_entreeruimte_temperature.state| float }
{{ (magazijntemp - entreetemp)|round(1) }}
What am I doing wrong here?
ok - all seem to bo clear ā¦
but - beginner quesion - where do I write this!?
writing this in my configuration, iāll only get errors ā¦
solved - no idea how or why I got the error bevore
would be great, if I could use only the combining helper for this usecase
like the āCombine Helperā- icon suggested:
Good day everyone⦠I tried to follow this post. Iām try to do something similar, but i have always error report from HA
Can you please check this code for me?
# Calculated Value Sensor : Battery_Garage_KWH
sensors:
Battery_Garage_KWH2:
entity_id:
- sensor.energy_meter_1_energia
- sensor.inv_gar_out_energia
value_template: =
{set BatGarIn2 = states.sensor.energy_meter_1_energia.state| float }
{set BatGarOut2 = states.sensor.inv_gar_out_energia.state| float }
{{ (BatGarIn2 - BatGarOut2)|round(1) }}
Hello, alternative suggestion outside template that works for me. Is to use node red and report the end result as a new entity exposed to HA. I can do this much more efficiently through function utilizing JS than Yaml in templates.
