MandeepR
(Mandeep)
May 13, 2025, 9:14am
1
Friends,
In the quest of cleaning up my config files, I added a folder “template” in the configuration and the following in the configuration yaml.
Blockquote
template:
sensor: !include_dir_merge_list ./templates
Blockquote
I have created a lot of template sensors that are in different files under the “template” foldor. I am getting the following error in the configuration.yaml file:
Incorrect type. Expected “array”.
Can you please help me resolve this error.
Troon
(Troon)
May 13, 2025, 9:17am
2
Do:
template: !include_dir_merge_list ./templates
then in your individual files, start like this:
- sensor:
- name: etc
MandeepR
(Mandeep)
May 13, 2025, 10:43am
3
Thanks for prompt reply. Howver, when i did what you said, all sensors disappeared.
Troon
(Troon)
May 13, 2025, 2:43pm
4
You need to include the - sensor: (or other subdomain) at the top of each file and indent them properly. Did you do that?
Please post your config as text not screenshots: I can’t copy your config to edit it to show you what I mean. Here’s examples from my system:
# configuration.yaml
template: !include_dir_merge_list templates
# templates/energy.yaml
- sensor:
- name: "Grid consumption"
unique_id: d4c56989-7dd6-4e03-90c7-efc22a55f1cc
[other config]
- name: "Electricity cost"
unique_id: 2ac05fc6-9850-490d-a471-dcbac024dbae
[other config]
# templates/binary_sensors.yaml
- binary_sensor:
- name: mild_weather
unique_id: 37e80ebe-4006-40e3-aead-6b512be6cd44
state: "{{ 10 < states('sensor.outside_temperature')|int(0) < 26 }}"
# templates/recent_motion.yaml
- trigger:
- platform: state
entity_id:
- binary_sensor.utility_room_motion
to: 'on'
- name: "Latest motion"
unique_id: 071ebe1d-c9f6-4f8e-b7f7-259528410d07
icon: mdi:run
device_class: timestamp
state: "{{ now() }}"
Your way should work if you only have simple (non-trigger-based) template sensors, and no other template entities like binary sensors, but you need to use:
template:
- sensor: !include_dir_merge_list ./templates
The sensor is a list header (docs ) and lists are dentoed in YAML with a hyphen.
