Hi Team,
Basically, i run the set up command(sudo python3 setup.py install) then i am getting some error while i am installing homeassistant 0.119 on ubuntu server 20.04.and error i have attached below please help me for solve this issue.
error:
Installed /usr/local/lib/python3.7/dist-packages/homeassistant-0.119.0.dev0-py3.7.egg
Processing dependencies for homeassistant==0.119.0.dev0
Searching for ciso8601==2.1.3
Reading https://pypi.org/simple/ciso8601/
Downloading https://files.pythonhosted.org/packages/2c/da/626910cf8aca7ed2d5b34355eee8aeaaeb6ddd4e16f98d00a9e2ddad3a08/ciso8601-2.1.3.tar.gz#sha256=bdbb5b366058b1c87735603b23060962c439ac9be66f1ae91e8c7dbd7d59e262
Best match: ciso8601 2.1.3
Processing ciso8601-2.1.3.tar.gz
Writing /tmp/easy_install-3dmei7sj/ciso8601-2.1.3/setup.cfg
Running ciso8601-2.1.3/setup.py -q bdist_egg --dist-dir /tmp/easy_install-3dmei7sj/ciso8601-2.1.3/egg-dist-tmp-qksaqm98
package init file ‘ciso8601/init.py’ not found (or not a regular file)
module.c:1:10: fatal error: Python.h: No such file or directory
1 | #include <Python.h>
compilation terminated.
error: Setup script exited with error: command ‘x86_64-linux-gnu-gcc’ failed with exit status 1
Most of the time these are dependency-issues. You need to install a package called python-dev. This package includes header files, a static library and development tools for building Python modules, extending the Python interpreter or embedding Python in applications. When encountering this error please note before the error it may say you are missing a package or header file — you should find those and install them and verify if it works
For Python 2.x use:
$ sudo apt-get install python-dev
If you using python3, try to replace python-dev with python3-dev
For a specific version of Python 3, replace x with the minor version in
$ sudo apt-get install python3.x-dev
