I installed Hassio on a VM using
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s
And then I installed the Let’s Encrypt add on.
"email": "[email protected]",
"domains": [
"example.com",
"mqtt.example.com",
"hassio.example.com"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
When I hit start, I get the following at the bottom of the addon screen:
starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
An unexpected error occurred:
ConnectionError: HTTPSConnectionPool(host=‘acme-v01.api.letsencrypt.org’, port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7f36a47a5590>: Failed to establish a new connection: [Errno -3] Try again’,))
Please see the logfiles in /var/log/letsencrypt for more details.
What am I doing wrong? (btw, i used Configurator to browse to /var/log and it’s emtpy)
