Hi, trying to integrate DeCONZ into HA, but having some problems. When I click add new integration --> DeCONZ Zigbee gateway, it just spins for a second and then I see errors in the logs. I never get the window popping up to confirm / submit the integration request.
I’ve tried doing this on several versions of HA (0.94.3, 0.93.2), and also tried an completly fresh HA-installation, same errors.
HA (not Hass.io) running in a container. Deconz running on a seperate Ubuntu virtual machine. Any ideas?
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/app/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/usr/src/app/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/usr/src/app/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/usr/src/app/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/usr/src/app/homeassistant/components/config/config_entries.py", line 120, in post
return await super().post(request)
File "/usr/src/app/homeassistant/components/http/data_validator.py", line 46, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/app/homeassistant/helpers/data_entry_flow.py", line 57, in post
handler, context={'source': config_entries.SOURCE_USER})
File "/usr/src/app/homeassistant/data_entry_flow.py", line 71, in async_init
return await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/app/homeassistant/data_entry_flow.py", line 123, in _async_handle_step
result = await getattr(flow, method)(user_input) # type: Dict
File "/usr/src/app/homeassistant/components/deconz/config_flow.py", line 76, in async_step_user
self.bridges = await async_discovery(session)
File "/usr/local/lib/python3.7/site-packages/pydeconz/utils.py", line 66, in async_discovery
response = await async_request(session.get, URL_DISCOVER)
File "/usr/local/lib/python3.7/site-packages/pydeconz/utils.py", line 91, in async_request
"Invalid content type: {}".format(res.content_type))
pydeconz.errors.ResponseError: Invalid content type: text/html
