Have recently installed ZHA. Works fine without issues. Except the input at my logfile which comes every hour:
“Temp & Luftfeuchte Sensor Arbeitszimmer Checkin event was fired”
No further issue. Sensor is always available. Have another sensor from aqara, which is sending every ~4-5 hours a logfile
I found an workaround which seems to be logical, but its not working for me:
From ZHA device card > Reconfigure > Manage zigbee device > (Clusters) PollControlcluster > (Attributes) checkin_interval and click read attribute. Mine for my water valve was 28 and way too frequent. I changed it to 500 and it doesn’t fill my logger anymore. You can change it to a higher value and test.
Have not such attributes
I have some questions on that:
how often will be the log file deleted? If it will be done i.e. every two days, than it should not become a file size issue.
Which workdaround do you recommend in case of a file size issue?
Thx for your help!
