Getting friendly name of a device in automation
Trying to create a blueprint for verifying that water sensor sends some update once per 54 minutes. If it doesn’t, I’m trying to send a persistent notification with the device name that failed to send the update. My problem is that I don’t seem to find a way to get a friendly name of the device. Any hints are appreciated! I have found similar questions related to state_change, but not for event.
blueprint:
  domain: automation
  name: Availability check for Aquara water sensor
  description: Script will notify if the sensor does not update at least every 54 minutes.
  input:
    zha_device:
      description: The sensor to be followed
      selector:
        device:
          integration: zha
          model: lumi.sensor_wleak.aq1
          multiple: false
  source_url:
mode: restart
max_exceeded: silent
variables:
  device_id: !input zha_device
- platform: event
  event_type: zha_event
condition: '{{ trigger.event.data.device_id == device_id }}'
  - service: logbook.log
      message: '{{ device_id }}'
  - delay:
      hours: 0
      minutes: 54
      seconds: 0
      milliseconds: 0
  - service: notify.persistent_notification
      title: Connection problem (Zigbee)
      message: Sensor {{ state_attr(device_id, 'name_by_user') }} report timeout!
This will trace “Sensor None…”. Using “friendly_name” gives the same.
A bit late maybe but I guess it could help someone else.
This should work to get the friendly_name:
message: Sensor {{ device_attr(device_id, 'name') | replace('_', ' ') }} report timeout!
