Hi everyone,
I’m pretty new to HA and right now i’m a little lost between helpers, templates and everything, so i need a little help to get things going.
I installed a tasmota counter device to my gas meter (D1 mini with reed sensor on a elster BK-G4 MT) and it showed up in HA as sensor.tasmota_counter_C1. In order to make it work as a suitable source for the energy dashboard i defined a template sensor:
- sensor:
- name: gas_verbrauch
state: |
{{(states('sensor.tasmota_counter_c1') | float(0) * 0.01)}}
state_class: total
device_class: gas
unit_of_measurement: m³
That worked fine, but now i have the problem, that a power loss on the tasmota counter resets the counter value to zero. I could save the counter value on the ESP periodically, but that’d brick it sooner or later and if i save less in order to save the flash memory i still have some kind of data loss.
So i came up with the following idea:
- In HA have an buffer counter that reflects the state of the tasmota counter sensor
- Also have an offset value
- If the tasmota counter is lower than the buffer counter (e.g. after blackout) increase offset value by buffer counter
- use offset value + tasmota counter for energy dashboard
Unfortunately i am pretty unsure if that’s a good idea to realize in HA, and if so, how to do it properly. Can you help me out? Any thoughts welcome.
Thanks in advance
