Getting Glances to run on reboot on RasPi
I’m sure I’m missing something obvious here since I’m new to Raspian but I cannot get Glances to run unless I open a Putty session and manual start it. It works, but of course it will die if I close the session.
I tried setting it up in crontab as the Pi user and even as the root and while both entries exist, neither one seems to start it up. I have it in like this:
@reboot glances -w
Any idea what I am doing wrong?
I have had issues with network enabled programs starting on boot. A couple of things that might help:
  1. Got to raspi-config and pick the “Wait for Network at Boot” option - sometimes, especially if you are using DHCP, the network doesn’t come up right away. Using systemd, things tend to boot a lot quicker so this can be an issue. Selecting wait at boot might do the trick.
  2. Write a simple script to call glances and put sleep 10 at the top to delay the startup.
I have solved similar issues with both of these techniques.
Good Luck!
Thanks for the advice; I’ll make those changes later and let you know if it solves the issue
But does my crontab entry look correct though? And which user should I create the entry under or does it even matter? (I’m assuming it’s OK or you would have mentioned it but just want to be sure.)
It looks OK to me - I’ll take a look at this as well because it would be cool to get glances running on all my PIs :slight_smile: I’ll let you know when I find a working combination.
Wouldn’t it be easier to use a systemd service unit? Like (untested):
[Unit]
Description=Glances daemon
After=network.target
[Service]
ExecStart=/usr/bin/glances -w
[Install]
WantedBy=multi-user.target
I took a similar approach and got it working just now, I used a startup script I found here
Grab the script and set it up as he describes, make sure it is executable:
$ sudo chmod +x /etc/init.d/glances
check it works:
$ sudo /etc/init.d/glances start
If all is well enable it for start on reboot:
$ sudo systemctl enable glances
Synchronizing state for glances.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d glances defaults
Executing /usr/sbin/update-rc.d glances enable
Works great for me! I couldn’t get it to work anyway using cron.
That worked fantastic, Andrew! Thank you very much for your help.
I pushed the script with WinSCP and then used that to edit it as directed in the source, then used WinSCP to modify the perms. The rest I did as you directed. (Just wanted to add this in case someone wanted another way to do it in a GUI).
Thanks again!
Anyone else who comes here in the future… please see
