Getting GPIO state
Hya,
in the process of leaning ESPHome, i’m trying to get the gpio state ( $RES_PIN) , but it’s failing.
When compiling, i get:
Compiling .pioenvs/education/src/main.cpp.o
<unicode string>: In lambda function:
<unicode string>:74:32: error: return-statement with a value, in function returning 'void' [-fpermissive]
*** [.pioenvs/education/src/main.cpp.o] Error 1
========================== [FAILED] Took 3.38 seconds ==========================
the code:
  LED_PIN: GPIO13 # D7
  BUT_PIN: GPIO12 # D6
  RES_PIN: GPIO14 # D5
binary_sensor:
  - platform: gpio
    pin: $BUT_PIN
    name: "Test LED Button"
    on_press:
      then:
        switch.toggle: led_red
  - platform: gpio
    pin: $RES_PIN
    on_press:
      then:
        lambda: |-
          return (id(resistance_wire).state);
    lambda: |-
      return (id(led_red).state);
switch:
  - platform: output
    output: output_led
output:
  - platform: gpio
    pin: $LED_PIN
    inverted: false
Advises, please?
Hello…
You don’t need this bit. You just set it up per the docs.
If you need to access the state for automations then start with a read of this.
Then this…
yes, i’m reading but not understanding how it works. i want to get the state (on / off) of gpio14. how shall i make use (initially displaying) without “return (id(resistance_wire).state)” ?
this is what i’m not getting.
now it works.
binary_sensor:
  - platform: gpio
    pin:
      number: $BUT_PIN
      mode:
        input: true
    on_press:
      then:
  - platform: gpio
    pin:
      number: $RES_PIN
      inverted: false
      mode:
        input: true
        pullup: true
    lambda: |-
    lambda: |-
switch:
  - platform: output
    output: output_led
output:
  - platform: gpio
    pin: $LED_PIN
    inverted: false
