My keypad controls a fanlic and it works well. The HA Insteon integration found the fan and keypad and I can control the light and fan (all 3 modes) from the Insteon fan/light card. However, the buttons on the Insteon keypad card are not communicating with the fanlinc. When toggled, the HA keypad buttons will control the keypad lights without changing the light of fan. Furthermore, whenever HA restarts, the keypad defaults to Fan Low. I’m looking for the settings that will link the keypad to the fanlinc and allow control of the keypad buttons. Thanks.
Did you ever figure this out? I’m in a similar boat
I created an automation that detects when the fanlinc are set in a range ie between 10% and 40%. It then set a trigger ID that and a choose function to pick the Trigger ID state. Then it will will call the insteon theme for fan off, low, medium or high. Here is the yaml file I hope it helps. I’m still learning but this does work for me.
alias: Kitchen Fan
description: ""
triggers:
- trigger: state
entity_id:
- light.fanlinc_53_34_54_light
to: "on"
enabled: true
- trigger: state
entity_id:
to: "off"
enabled: true
- trigger: numeric_state
entity_id:
- fan.fanlinc_53_34_54_fan
attribute: percentage
above: 10
below: 39
entity_id:
above: 40
below: 79
entity_id:
above: 80
- trigger: state
entity_id:
to: "off"
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- Light On
sequence:
- action: light.turn_on
entity_id:
- light.keypad_with_dimmer_58_8c_f8_main
data: {}
- conditions:
id:
- Light Off
sequence:
- action: light.turn_off
entity_id:
data: {}
- conditions:
id:
- fan low
sequence:
- action: insteon.scene_on
group: 37
- conditions:
id:
- fan med
sequence:
group: 38
- conditions:
id:
- fan high
sequence:
group: 36
- conditions:
id:
- fan off
sequence:
group: 40
mode: single
