I re purposed my nest thermostat for a dial for the media player. The nest component in HA reacted too slow so I wrote the program that will update a mqtt feed immediately when nest changes temperature set. HA can then pick up that nest mqtt feed for a sensor.
I run this script when my computer start. You will need to get a free developers nest api token from their website.
#!/usr/bin/env python3
import sseclient
import urllib3
import certifi
import json
import pprint
import collections
import os
import aiohttp
import asyncio
import logging
import paho.mqtt.client as paho
import time
def on_connect(client, userdata, flags, rc):
if rc == 0:
print("Connected to broker")
global Connected #Use global variable
Connected = True #Signal connection
else:
print("Connection failed")
Connected = False #global variable for the state of the connection
broker_address="192.168.2.150"
port=1883
user = ""
password = ""
os.environ["NEST_TOKEN"] = "token"
os.environ["THERMOSTAT_ID"] = "id"
from itertools import islice
# initialize logger and set log level based on DEBUG mode
_LOGGER = logging.getLogger(__name__)
DEBUG = os.environ.get('DEBUG',False)
logging.basicConfig(level=(logging.DEBUG if DEBUG else logging.INFO),
format='%(relativeCreated)6d %(threadName)s %(message)s')
# set HTTP logging based on DEBUG mode
if DEBUG:
try:
import http.client as http_client
except ImportError:
# Python 2
import httplib as http_client
http_client.HTTPConnection.debuglevel = 1
# get the Nest API auth token from the environment
TOKEN = os.environ.get("NEST_TOKEN")
NEST_API_URL = 'https://developer-api.nest.com/devices/thermostats/{0}/target_temperature_f'.format(os.environ.get('THERMOSTAT_ID'))
ALWAYS_UNLOCK = os.environ.get('ALWAYS_UNLOCK',False)
def window(seq, n=2):
"Returns a sliding window (of width n) over data from the iterable"
" s -> (s0,s1,...s[n-1]), (s1,s2,...,sn), ... "
it = iter(seq)
result = tuple(islice(it, n))
if len(result) == n:
yield result
for elem in it:
result = result[1:] + (elem,)
yield result
def new_tumbler():
"Returns a new empty deque representing a tumbler."
return collections.deque(20*[0],20)
async def get_data_stream(session, loop, token, api_endpoint):
Listens to a Nest thermostat and disarms the alarm if the
right combination is found inside the stream of changing temperatures.
# initialize an empty tumbler
tumbler = new_tumbler()
# set up the HTTP call to the Nest API
headers = {
'Authorization': "Bearer {0}".format(token),
'Accept': 'text/event-stream'
http = urllib3.PoolManager(cert_reqs='CERT_REQUIRED',
ca_certs=certifi.where())
# call Nest API and get back a blocking generator of Nest events
response = http.request('GET', api_endpoint, headers=headers, preload_content=False)
client = sseclient.SSEClient(response)
# loop over the generator indefinitely and handle the incoming events
for event in client.events():
event_type = event.event
_LOGGER.debug("event: {0}".format(event_type))
# most of these events don't matter to us
if event_type == 'open':
_LOGGER.info("The event stream has been opened")
elif event_type == 'keep-alive':
_LOGGER.info("No data updates. Receiving an HTTP header to keep the connection open.")
elif event_type == 'auth_revoked':
_LOGGER.error("The API authorization has been revoked.")
_LOGGER.error("revoked token: ", event.data)
elif event_type == 'error':
_LOGGER.error("Error occurred, such as connection closed.")
_LOGGER.error("error message: ", event.data)
# ok, this is the event we care about
elif event_type == 'put':
_LOGGER.debug("The data has changed (or initial data sent)")
data = json.loads(event.data)
# put the new value into the tumbler
tumbler.append(data["data"])
print (tumbler);
print ("changed", data["data"]);
client= paho.Client("Python")
client.connect(broker_address, port=port) #connect to broker
client.loop_start() #start the loop
value = data["data"]
client.publish("mac/nest/tempset",value)
client.disconnect()
client.loop_stop() #stop loop
_LOGGER.info("Tumbler is now {0}".format(tumbler))
else:
_LOGGER.error("Unknown event, no handler for it.")
async def main(loop):
async with aiohttp.ClientSession() as session:
await get_data_stream(session, loop, TOKEN, NEST_API_URL)
if __name__ == '__main__':
loop = asyncio.get_event_loop()
loop.run_until_complete(main(loop))
I got the idea / code from here
