Getting I/o errors with SSD upgrade
I run home assistant on a GeekPi NAS Kit booting from a 128 GB ssd. All was running fine, but with Plex, i ran into storage issues, with that thought i bought a new 1Tb SSD( as the case can support upto 2TB) which should be fine for my media consumption.
The problem is, that when i put in the 1TB SSD,the system starts to give me I/O errors and i have to hard boot it in a few hrs, Even though using the scruitny add on, it says drive is healthy.
The system has been running rock solid with the 128GB SSD in place.
Steps i have already tried:
Change the SSD with the new one, got the same error. Hence reaching out
Changed the power supply to official one
The error’s that i get :
Please help
EDIT: I also see the below logs under host:
Aug 04 06:42:14 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.vWFZel.mount: Deactivated successfully.
Aug 04 06:43:14 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.6qyETK.mount: Deactivated successfully.
Aug 04 06:43:44 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.OvzXaH.mount: Deactivated successfully.
Aug 04 06:44:32 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.3STKmI.mount: Deactivated successfully.
Aug 04 06:50:46 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.I0MenD.mount: Deactivated successfully.
Aug 04 06:55:48 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.g5czSU.mount: Deactivated successfully.
Aug 04 06:58:07 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.hOFaBt.mount: Deactivated successfully.
Aug 04 07:00:37 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.xMzqPq.mount: Deactivated successfully.
Aug 04 07:01:38 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.BEgpWi.mount: Deactivated successfully.
Aug 04 07:02:50 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.mWBfwo.mount: Deactivated successfully.
Aug 04 07:03:08 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.N7yp61.mount: Deactivated successfully.
Aug 04 07:03:50 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.qsoL36.mount: Deactivated successfully.
Aug 04 07:05:09 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.hmiJwv.mount: Deactivated successfully.
Aug 04 07:06:51 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.laburX.mount: Deactivated successfully.
Aug 04 07:08:40 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.HDlReo.mount: Deactivated successfully.
Aug 04 07:11:11 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.TGex2j.mount: Deactivated successfully.
Aug 04 07:11:22 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.9vEt3h.mount: Deactivated successfully.
Aug 04 07:14:12 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.ejvwLF.mount: Deactivated successfully.
Aug 04 07:15:53 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.qSVI4V.mount: Deactivated successfully.
Aug 04 07:16:23 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.dgfwup.mount: Deactivated successfully.
Aug 04 07:19:24 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.2OFJ2r.mount: Deactivated successfully.
Aug 04 07:19:44 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.xy3wGI.mount: Deactivated successfully.
Aug 04 07:20:44 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.1UPOyM.mount: Deactivated successfully.
Aug 04 07:21:14 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.WfSKbG.mount: Deactivated successfully.
Aug 04 07:21:44 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.ptr3wd.mount: Deactivated successfully.
Aug 04 07:23:15 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.zhZiVE.mount: Deactivated successfully.
Aug 04 07:26:26 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.qkZmaP.mount: Deactivated successfully.
Aug 04 07:26:57 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.5tuQLQ.mount: Deactivated successfully.
Aug 04 07:30:17 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.h8cz6w.mount: Deactivated successfully.
Aug 04 07:30:48 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.kPqqNE.mount: Deactivated successfully.
Aug 04 07:31:28 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.XoNLcY.mount: Deactivated successfully.
Aug 04 07:32:28 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.7xDo80.mount: Deactivated successfully.
Aug 04 07:34:19 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.G2obiG.mount: Deactivated successfully.
Aug 04 07:35:19 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.zbak6I.mount: Deactivated successfully.
Aug 04 07:35:29 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.k6OwaO.mount: Deactivated successfully.
Aug 04 07:35:49 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.CIWTv7.mount: Deactivated successfully.
Aug 04 07:36:29 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-c70272831eae3036e496303d86c048eb6d0842ced0a5623efdcec014910a8aee-runc.26ueaR.mount: Deactivated successfully.
Aug 04 07:36:50 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-e42c96c07c66f136bcd5d7b48cb3bdc728d461a2ee7b45dabf2eb0869d19d6f7-runc.aE1eWM.mount: Deactivated successfully.
type or paste code here
