Getting Insteon "Links"?
I have gotten all my devices from my hub into HA. I have a couple of places where I have 2 2477D dimmer switches acting like 3-way switches. I think that is “linking”. I thought I could get that link information out of the hub by using a service like:
service: insteon.load_all_link_database
  entity_id: light.switchlinc_dimmer_33_a9_6f
and then display that information with:
service: insteon.print_all_link_database
When I execute the service calls, I get a green check box, but nothing “printed” anywhere. Is it possible that this “link” is just in the hardware between the 2 switches and the Insteon app “links” are a different thing and they actually don’t exist for me?
What is the expected output of running these 2 services?
Also,
My hub definitely has “scenes”. Can I get those out of the hub and into the HA Scenes?
I have the exact same issue, except I’m including the word “all” as the entity ID, but nothing happens, nothing prints, nothing shows up in the logs or history … stumped
Did you figure out a solution to the issue?
Not me. Surprised someone else doesn’t have the solution to this. Seems like all of us Insteon folks would want to do this.
I found this thread last night and was able to get it to print:
Thanks. I’ll see what I can figure out from that thread.
… time passes …
Ok, I see stuff in the log now. I don’t know how I missed that you have to set up the log. (Maybe it wasn’t stated).
I added this to configuration:
logger:
  default: warn
  logs:
    homeassistant.components.insteon: info
