Insteon - insteon.print_im_all_link_database - Where does it end up?
Greetings,
I want to back up my 2413U PLM database. Might need to restore it later.
From the “Developers Tools” I initiated the service: insteon.print_im_all_link_database. Nothing happened that I could see. Checked the logs, etc…
Running latest 104.3 on a NUC/Ubuntu. HASS docker containers.
Thanks.
The output appears in the HA log. This can be seen in the Developer Tools menu under logs. The insteon component must be set to info level logs however. This can by done in the configuration file with the following setup:
logger:
  default: warn
  logs:
    homeassistant.components.insteon: info
Alternatively you can make the default info which will put all components to the info level of logging. It does create a bigger log but that is personal preference.
Thank you! I didn’t have the log level set properly. Also, thanks for all your work on Insteon. It’s a key piece of our HA technology.
Greetings,
I’m new to Home Assistant and I’m trying to look at log entries related to the Insteon integration. The entry by teharris1 suggests logs can be seen in the Developer Tools menu under logs. I do not see an option to view logs here. Can anyone help me?
To see the logs go to ConfigurationSettingsLogs
I’m trying everything and can’t seem to get either the load all links or the print all links function to work
I clicked on load all links 5 times, each time waiting 30 minutes before I touch the system again and when I go to the logs under configuration>settings, it doesn’t show anything related to links. Just a bunch of error messages
Any help would be GREATLY appreciated
Cleared all my logs, ran it again last night, have turned lights on and off this morning, and this is all there is:
2022-04-22 19:22:46 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-04-22 19:22:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-23 11:39:00 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [547972572592] Disconnected: Did not receive auth message within 10 seconds
@teharris1 if there’s anything that comes to mind let me know and Il I’ll try it as you’re the guru :slightly_smiling_face:
Can you post the error messages?
Is there a command through which I can see or download the total PLM data base. The services under Developer seem to be aimed at single device/entity/
Hi @teharris1,
Like others I’m new here, working on getting my Insteon hub and devices operational. Thanks for all of your patience with us newbies.
I want to make the change you show above, to be able to see the log output of this command, but after hunting around I am still not able to locate the configuration file to add the logger setup. I’m running HA in Virtual Box. Any direction would be greatly appreciated!
Good news, if you can wait a week. The device control panel code just got merged into the core code.This will give you a user interface to manage your All-Link Database so the info in this thread will be out of date. If you have to have it before then let me know.
That’s great! I can wait for it. Thanks!
These are most of my logs:
2022-04-28 17:50:44 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:50:50 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:50:59 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:51:10 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:51:14 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:51:29 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:51:39 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:51:44 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:51:59 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:52:14 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:52:29 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:52:30 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:52:45 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:53:00 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:53:15 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:53:30 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:53:45 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:53:46 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:54:00 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:54:15 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:54:30 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:54:45 ERROR (MainThread) [hass_nabucasa.remote] Can’t update remote details from Home Assistant cloud
2022-04-28 17:56:03 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 17:57:16 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer
2022-04-28 17:57:24 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:57:24 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:57:36 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:57:36 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:57:49 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:57:49 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:58:00 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:58:00 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:58:18 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:58:18 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:58:24 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:58:24 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:58:44 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:58:44 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:00 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:00 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:13 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:13 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:23 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:23 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:32 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:32 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:38 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:38 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 17:59:52 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 17:59:52 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:00:08 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:00:08 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:00:20 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:00:20 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:00:38 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:00:38 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:00:46 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:00:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:00:48 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2022-04-28 18:00:58 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:00:58 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:01:08 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:01:08 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:01:24 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:01:24 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:01:31 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:01:31 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:01:38 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:01:38 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:01:47 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:01:47 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:02:05 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:02:05 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:02:24 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:02:24 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:02:33 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:02:33 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:02:40 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:02:40 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:02:50 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:02:50 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:03:07 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:03:07 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:03:17 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:03:17 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:03:27 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:03:27 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:03:45 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:03:45 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:03:52 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:03:52 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 18:04:00 ERROR (MainThread) [snitun.client.client_peer] Can’t connect to SniTun server us-east-1-3.ui.nabu.casa:443 with: [Errno -3] Try again
2022-04-28 18:04:00 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-04-28 19:11:54 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:11:57 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:11:58 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:11:59 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:01 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:04 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:12 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:14 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:30 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:12:45 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:13:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:13:15 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:13:30 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:13:45 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:14:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:14:16 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:14:31 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:14:46 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:15:01 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:15:16 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:15:31 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:15:46 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:16:02 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:16:17 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:16:25 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:16:40 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:16:55 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:17:11 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:17:26 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:17:41 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:17:56 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:18:11 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:18:26 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:18:42 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:18:57 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:19:12 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:19:27 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:19:42 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:19:57 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:20:13 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:20:28 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:20:43 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:20:45 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:21:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:21:15 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:21:30 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:21:46 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:22:01 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:22:16 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:22:31 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:22:46 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:23:01 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:23:16 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:23:32 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:23:47 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:24:02 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:24:17 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:24:32 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:24:47 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:25:02 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:25:18 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:25:33 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:25:48 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:26:03 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:26:18 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:26:33 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-28 19:26:48 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.85 (192.168.1.85). (Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.4.1))
2022-04-29 06:25:09 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [548085804912] Disconnected: Did not receive auth message within 10 seconds
2022-04-29 10:45:32 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:47:31 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 502, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:47:50 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:54:28 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 502, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:54:48 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:55:11 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 10:55:47 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:05:55 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:06:13 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:06:40 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:07:00 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 503, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:07:49 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:09:14 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 11:11:44 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 12:14:20 ERROR (MainThread) [pyinsteon.protocol.http_reader_writer] Client error: (<class ‘aiohttp.client_exceptions.ClientOSError’>) [Errno 104] Connection reset by peer
2022-04-29 14:57:10 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 503, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 14:57:29 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 14:57:50 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 14:58:25 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 14:59:13 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 15:00:34 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: 504, message=‘Invalid response status’, url=URL(‘wss://cloud.nabucasa.com/websocket’)
2022-04-29 17:42:54 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from DESKTOP-VIRFSKD.lan (192.168.1.172). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.127 Safari/537.36)
What is the “device control panel”?
In 2022.5 you will see a new side menu labeled “Insteon”. This link will display a list of your Insteon devices. Clicking on any device will allow you to configure the device and update the link database directly. 2022.5 is due out on Wednesday.
Sounds good. I was JUST trying to see if there was a 2022.5 update and couldn’t quite figure out how to DO an update as I’m a newbie. (and fairly new with Synology NAS and totally new to Docker) So there was some to figure out, but I guess I will try again on Wednesday. Thanks.
Now I’m trying to figure out what the link database output is telling me.
I presume the link database is not related to scenes and schedules, but is there something to list those that I haven’t noticed yet?
I am waiting with baited breath!
2022.5 was released earlier today. You should be able to upgrade to it now.
All Hail Tom Harris!!! For all of us that have stumbled onto Home Assistant after being abandoned by Insteon I offer our heart felt appreciation for your great work in developing the Insteon panel!!! Do you have a Patreon or similar account?
