Getting internal server error in overserr and sabnzbd’s ui just openes a new home assistant instance
Supervisor logs are aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error ‘TimeoutError’
2025-01-11 07:17:19.950 ERROR (MainThread) [homeassistant.components.met.coordinator] Error fetching met data: Update failed:
2025-01-11 07:32:44.546 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [140427051594896] from 192.168.1.23 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.1.1 Safari/605.1.15): Disconnected: Received close message during auth phase
Sabnzdb logs are
Add-on: SABnzbd
Free and easy binary newsreader
Add-on version: 0.3.2
You are running the latest version of this add-on.
System: Home Assistant OS 14.1 (amd64 / qemux86-64)
Home Assistant Core: 2025.1.2
Home Assistant Supervisor: 2024.12.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-sabnzbd: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-sabnzbd successfully started
s6-rc: info: service sabnzbd: starting
s6-rc: info: service sabnzbd successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[23:01:20] INFO: Starting SABnzbd…
2025-01-10 23:01:39,394::INFO::[SABnzbd:1139] Console logging only
2025-01-10 23:01:39,395::INFO::[SABnzbd:1142] --------------------------------
2025-01-10 23:01:39,395::INFO::[SABnzbd:1143] SABnzbd.py-4.4.1
2025-01-10 23:01:39,398::INFO::[SABnzbd:1153] Commit = f81a8c97c4e79aead99015ca027e76d642548d22
2025-01-10 23:01:39,405::INFO::[SABnzbd:1155] Full executable path = /opt/SABnzbd.py
2025-01-10 23:01:39,405::INFO::[SABnzbd:1156] Arguments = “/opt/SABnzbd.py” “–config-file” “/config” “–server” “0.0.0.0” “–console” “–disable-file-log”
2025-01-10 23:01:39,406::INFO::[SABnzbd:1157] Python-version = 3.12.8 (main, Dec 7 2024, 05:56:13) [GCC 14.2.0]
2025-01-10 23:01:39,406::INFO::[SABnzbd:1158] Dockerized = True
2025-01-10 23:01:39,406::INFO::[SABnzbd:1159] CPU architecture = x86_64
2025-01-10 23:01:39,489::INFO::[SABnzbd:1162] Platform = posix - Linux-6.6.66-haos-x86_64-with
2025-01-10 23:01:39,489::INFO::[SABnzbd:1168] Preferred encoding = UTF-8
2025-01-10 23:01:39,490::INFO::[SABnzbd:1190] SSL version = OpenSSL 3.3.2 3 Sep 2024
2025-01-10 23:01:39,510::INFO::[SABnzbd:1199] Certifi version = 2024.08.30
2025-01-10 23:01:39,513::INFO::[SABnzbd:1200] Loaded additional certificates from /usr/lib/python3.12/site-packages/certifi/cacert.pem
2025-01-10 23:01:39,514::INFO::[SABnzbd:1210] Using INI file /config/sabnzbd.ini
2025-01-10 23:01:39,535::INFO::[postproc:143] Loading postproc queue
2025-01-10 23:01:39,547::INFO::[scheduler:190] Scheduling RSS interval task every 60 min (delay=57)
2025-01-10 23:01:39,547::INFO::[scheduler:200] Scheduling version check in 10 minutes and daily at 18:40
2025-01-10 23:01:39,547::INFO::[scheduler:215] Setting schedule for midnight auto history-purge
2025-01-10 23:01:39,550::INFO::[scheduler:224] Setting schedule for midnight BPS reset
2025-01-10 23:01:39,550::INFO::[scheduler:233] Setting schedule for midnight server expiration check
2025-01-10 23:01:39,554::INFO::[scheduler:242] Setting schedule for server quota check
2025-01-10 23:01:39,555::INFO::[init:303] All processes started
2025-01-10 23:01:39,563::INFO::[SABnzbd:340] Template location for Glitter is /opt/interfaces/Glitter
2025-01-10 23:01:39,566::INFO::[SABnzbd:340] Template location for Config is /opt/interfaces/Config
2025-01-10 23:01:39,579::INFO::[misc:1260] [N/A] Running external command: [‘/usr/local/bin/unrar’]
2025-01-10 23:01:39,732::INFO::[misc:1260] [N/A] Running external command: [‘/usr/bin/7zz’]
2025-01-10 23:01:39,795::INFO::[misc:1260] [N/A] Running external command: [‘/usr/bin/par2’, ‘-V’]
2025-01-10 23:01:39,873::INFO::[SABnzbd:425] SABCTools module (v8.2.5)… found!
2025-01-10 23:01:39,873::INFO::[SABnzbd:426] SABCTools module is using SIMD set: AVX
2025-01-10 23:01:39,873::INFO::[SABnzbd:427] SABCTools module is linked to OpenSSL: True
2025-01-10 23:01:39,873::INFO::[SABnzbd:447] Cryptography module (v44.0.0)… found!
2025-01-10 23:01:39,874::INFO::[SABnzbd:453] par2 binary… found (/usr/bin/par2)
2025-01-10 23:01:39,874::INFO::[SABnzbd:460] UNRAR binary… found (/usr/local/bin/unrar)
2025-01-10 23:01:39,874::INFO::[SABnzbd:468] UNRAR binary version 6.24
2025-01-10 23:01:39,874::INFO::[SABnzbd:475] 7za binary… found (/usr/bin/7zz)
2025-01-10 23:01:39,874::INFO::[SABnzbd:477] 7za binary version 24.08
2025-01-10 23:01:39,874::INFO::[SABnzbd:483] nice binary… found (/bin/nice)
2025-01-10 23:01:39,879::INFO::[SABnzbd:487] ionice binary… found (/bin/ionice)
2025-01-10 23:01:39,888::INFO::[SABnzbd:1404] Starting web-interface on 0.0.0.0:8080
2025-01-10 23:01:39,888::INFO::[_cplogging:213] [10/Jan/2025:23:01:39] ENGINE Bus STARTING
2025-01-10 23:01:40,067::INFO::[_cplogging:213] [10/Jan/2025:23:01:40] ENGINE Serving on 0.0.0.0:8080
2025-01-10 23:01:40,067::INFO::[_cplogging:213] [10/Jan/2025:23:01:40] ENGINE Bus STARTED
2025-01-10 23:01:40,068::INFO::[SABnzbd:1443] Starting SABnzbd.py-4.4.1
2025-01-10 23:01:40,102::INFO::[dirscanner:112] Dirscanner starting up
2025-01-10 23:01:40,110::INFO::[panic:239] Launching browser with http://127.0.0.1:8080
2025-01-10 23:01:40,135::INFO::[notifier:157] Sending notification: SABnzbd - SABnzbd 4.4.1 started (type=startup, job_cat=None)
2025-01-10 23:01:40,149::INFO::[zconfig:61] No bonjour/zeroconf support installed
2025-01-10 23:01:40,179::INFO::[ssdp:108] Serving SSDP on 172.30.33.15 as SABnzbd
[23:01:40] INFO: Starting NGinx…
I have the same issue. On a fresh install on HA OS (Odroid).
It’s stuck at Startin NGinx…
