I’m getting an invalid configuration error after adding Abode to my configuration.yaml. I’ve added only the bare minimum config and verified that the username and password are correct, so I’m not sure where I’m going wrong. Thanks in advance for any help. Edit: I’m using version 0.56.2
Here’s what I added:
abode:
username: XXXXXXXXXXX
password: XXXXXXXXXXX
Here’s the error I’m getting in the log:
2017-11-04 01:01:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component abode
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/abode.py", line 123, in setup
from abodepy.exceptions import AbodeException
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/abodepy/__init__.py", line 37, in <module>
from abodepy.event_controller import AbodeEventController
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/abodepy/event_controller.py", line 15, in <module>
from urllib3.exceptions import HTTPError
ImportError: No module named 'urllib3'
