Hi
I have spend the 6 hours and am at a loss as to how to fix this problem. I googled and tried every thing I’ve found. You guys are my last hope.
Here is the error message:
Error while executing automation automation.ifttt_starts_the_timer. Invalid data for call_service at pos 2: offset “00:02:00” should be format ‘HH:MM’ or ‘HH:MM:SS’ for dictionary value @ data[‘duration’]
The following is my automation code:
- id: start_timer_for_iftt_events
alias: IFTTT starts the timer
platform: event
event_type: ifttt_webhook_received
event_data:
action: start_timer
- service: timer.start
data_template:
duration: >
{% set temp = 16 %}
{% if temp > 25 %}
"00:01:00"
{% elif temp > 15%}
"00:02:00"
{% elif temp > 8%}
"00:03:00"
{% else %}
"00:04:00"
{% endif %}
entity_id: '{{ trigger.event.data.entity_id }}'
Regards,
