Hi i set up everything for my ESP8266 like described here: Remote Transmitter — ESPHome
The dump of my raw remote signal looks like this:
[16:00:54][D][remote.raw:028]: Received Raw: -9070, 4510, -576, 568, -571, 564, -601, 538, -599, 540, -597, 541, -575, 564, -598, 541, -573, 566, -597, 541, -574, 565, -599, 539, -573, 566, -598, 1653, -599, 1652, -574, 565, -573, 565, -573, 566, -575, 1675, -599, 541, -598, 540,
[16:00:54][D][remote.raw:041]: -574, 565, -573, 566, -573, 565, -599, 540, -598, 1652, -599, 539, -573, 1677, -573, 1677, -597, 1653, -574, 1677, -598, 1653, -599, 1652, -599
[16:00:54][D][remote.raw:041]: Received Raw: -9073, 2233, -574
What does 28 and 41 mean? Anything to do with the 38kHz frequency?
Do i have to copy all numbers or only parts of those to my config?
Because right now i have this config and it does not control my device:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "XXX"
password: "XXX"
ap:
ssid: "Remote Fallback Hotspot"
password: "XXX"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
remote_receiver:
pin: D1
dump: all
remote_transmitter:
pin: D2
# Infrared remotes use a 50% carrier signal
carrier_duty_percent: 50%
switch:
turn_on_action:
- remote_transmitter.transmit_raw:
carrier_frequency: 38kHz
code: [-9073, 2233, -574]
turn_on_action:
code: [-9070, 4510, -576, 568, -571, 564, -601, 538, -599, 540, -597, 541, -575, 564, -598, 541, -573, 566, -597, 541, -574, 565, -599, 539, -573, 566, -598, 1653, -599, 1652, -574, 565, -573, 565, -573, 566, -575, 1675, -599, 541, -598, 540,-574, 565, -573, 566, -573, 565, -599, 540, -598, 1652, -599, 539, -573, 1677, -573, 1677, -597, 1653, -574, 1677, -598, 1653, -599, 1652, -599]
name: Button RAW Long
turn_on_action:
code: [-9070, 4510, -576, 568, -571, 564, -601, 538, -599, 540, -597, 541, -575, 564, -598, 541, -573, 566, -597, 541, -574, 565, -599, 539, -573, 566, -598, 1653, -599, 1652, -574, 565, -573, 565, -573, 566, -575, 1675, -599, 541, -598, 540,-574, 565, -573, 566, -573, 565, -599, 540, -598, 1652, -599, 539, -573, 1677, -573, 1677, -597, 1653, -574, 1677, -598, 1653, -599, 1652, -599, 9073, -2233, 574]
I tried adding the last few numbers -9073, 2233, -574, but inverted, because otherwise it gives me
Values must alternate between being positive and negative, please see index 67 and 68.
