The current implementation of the Google Calendar component only retrieves a minimum of attributes from the Calendar API. There are much more of them and some would be really useful to have.
I have some amateur knowledge of Python and would give a try to a PR but after having a look at the code, I would be grateful if someone could do a quick go-through the way the data is actually retrieved.
Specifically, I see that in https://github.com/home-assistant/core/blob/4518dad83b47d63b76912c444ab4be159bc6af18/homeassistant/components/google/calendar.py#L546 an Event
is loaded into a CalendarEvent
which only defines (at https://github.com/home-assistant/core/blob/4518dad83b47d63b76912c444ab4be159bc6af18/homeassistant/components/calendar/init.py#L335)
start: datetime.date | datetime.datetime
end: datetime.date | datetime.datetime
summary: str
description: str | None = None
uid: str | None = None
recurrence_id: str | None = None
rrule: str | None = None
Couldn’t CalendarEvent
be extended to account for GC attributes such as colorId
or others? Is there a string dependency on that specific structure?
