Getting Nginx Reverse Proxy to work with Libreelec and VPN
Hi. I am looking for a guide on setting up reverse proxy for home assistant where the nginx proxy server is on a macvlan docker.
A little background:-
I have libreelec running on raspberry pi 4. the libreelec (kodi) uses a VPN connection. Because of this, Home assistant cannot be accessed from outside the home network.
I have installed Home Assistant via docker using this code:-
docker run -d --name="home-assistant" -v /storage/hass-config:/config -v /etc/localtime:/etc/localtime:ro -p 8123:8123/tcp --net=host --restart=unless-stopped homeassistant/raspberrypi4-homeassistant:stable
Then I created a Macvlan network for docker by
 docker network create -d macvlan \
  --subnet=192.168.1.0/24 \
  --gateway=192.168.1.254 \
  -o parent=eth0 pub_net
I then installed nginx reverse proxy on a separate docker with this command
docker create --name=swag --cap-add=NET_ADMIN --net=pub_net --ip=192.168.1.131 -e PUID=1000 -e PGID=1000 -e TZ=Asia/Kuala_Lumpur -e URL=subdomain.duckdns.org -e SUBDOMAINS=www,ha -e VALIDATION=http -e [email protected] -p 443:443 -p 80:80 -v /storage/letsencrypt:/config --restart unless-stopped linuxserver/letsencrypt
nginx is technically working as I can see the sample site. However, I am struggling to configure the default file and the homeassistant.subdomain.conf file. I keep getting a bad gateway error
I hope someone can point me in the right direction
My previous configuration is here. Trying to get reverse proxy to work
This wont work with VPN.
I don’t clearly see the link between HA, libreelec and the need for a macvlan here, tbh.
Is everything on the same machine? So, basically, librelec + docker, with HA as a container?
Hi.
Libreelec with HA as docker container works fine. However, when i try to use vpn, it kills of all incoming connection from outside the network.
To bypass vpn, the docker needs its own network interface.
Your internat router is 192.168.1.254, right?
Do you forward port 443 to 192.168.1.131 on it?
Can you ping nginx from the router?
If so, then I guess nginx should be configured with the 192.168.1.x of the host machine, as HA is still using host networking
Yes correct.
Yes i did
I am able to access the nginx server to its default html page.
I configured the reverse proxy using the sample file for home assistant.
So if i use www subdomain, i get to access the
# Welcome to your [SWAG](https://github.com/linuxserver/docker-swag) instance
A webserver and reverse proxy solution brought to you by [linuxserver.io](https://www.linuxserver.io/) with php support and a built-in Certbot client.
We have an article on how to use swag here: [docs.linuxserver.io](https://docs.linuxserver.io/general/swag)
For help and support, please visit: [linuxserver.io/support](https://www.linuxserver.io/support)
If i use the subdomain homeassistant.duckdns then i get bad gateway. Im guessing that nginx cannot see home assistant.
The router can see nginx
What do your nginx *.conf contain?
homeassistant.subdomain.conf contents are as follows
## Version 2021/07/13
# make sure that your dns has a cname set for homeassistant and that your homeassistant container is not using a base url
# As of homeassistant 2021.7.0, it is now required to define the network range your proxy resides in, this is done in Homeassitants configuration.yaml
# https://www.home-assistant.io/integrations/http/#trusted_proxies
# Example below uses the default dockernetwork ranges, you may need to update this if you dont use defaults.
# http:
#   use_x_forwarded_for: true
#   trusted_proxies:
#     - 172.16.0.0/12
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name homeassistant.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth, fill in ldap details in ldap.conf
    #include /config/nginx/ldap.conf;
    # enable for Authelia
    #include /config/nginx/authelia-server.conf;
    location / {
        # enable the next two lines for http auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        # enable the next two lines for ldap auth
        #auth_request /auth;
        #error_page 401 =200 /ldaplogin;
        #include /config/nginx/authelia-location.conf;
        include /config/nginx/proxy.conf;
        include /config/nginx/resolver.conf;
        set $upstream_app homeassistant;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass http://192.168.1.84:8123;
    location /api {
    location /local {
the default file contents are as follows
## Version 2021/04/27 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/default
error_page 502 /502.html;
# redirect all traffic to https
server {
    listen 80 default_server;
    listen [::]:80 default_server;
    server_name _;
    return 301 https://$host$request_uri;
# main server block
server {
    listen 443 ssl http2 default_server;
    listen [::]:443 ssl http2 default_server;
    root /config/www;
    index index.html index.htm index.php;
    server_name _;
    # enable subfolder method reverse proxy confs
    include /config/nginx/proxy-confs/*.subfolder.conf;
    # all ssl related config moved to ssl.conf
    # enable for geo blocking
    # See /config/nginx/geoip2.conf for more information.
    #if ($allowed_country = no) {
    #return 444;
    location / {
        try_files $uri $uri/ /index.html /index.php?$args =404;
    location ~ \.php$ {
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass 127.0.0.1:9000;
        fastcgi_index index.php;
        include /etc/nginx/fastcgi_params;
# sample reverse proxy config for password protected couchpotato running at IP 192.168.1.50 port 5050 with base url "cp"
# notice this is within the same server block as the base
# don't forget to generate the .htpasswd file as described on docker hub
#    location ^~ /cp {
#        auth_basic "Restricted";
#        auth_basic_user_file /config/nginx/.htpasswd;
#        include /config/nginx/proxy.conf;
#        proxy_pass http://192.168.1.50:5050/cp;
# sample reverse proxy config without url base, but as a subdomain "cp", ip and port same as above
# notice this is a new server block, you need a new server block for each subdomain
#server {
#    listen 443 ssl http2;
#    listen [::]:443 ssl http2;
#    root /config/www;
#    index index.html index.htm index.php;
#    server_name cp.*;
#    include /config/nginx/ssl.conf;
#    client_max_body_size 0;
#    location / {
#        proxy_pass http://192.168.1.50:5050;
# sample reverse proxy config for "heimdall" via subdomain, with ldap authentication
# ldap-auth container has to be running and the /config/nginx/ldap.conf file should be filled with ldap info
#server {
#    root /config/www;
#    server_name heimdall.*;
#    include /config/nginx/ldap.conf;
#    location / {
#        # the next two lines will enable ldap auth along with the included ldap.conf in the server block
#        auth_request /auth;
#        error_page 401 =200 /ldaplogin;
#        resolver 127.0.0.11 valid=30s;
#        set $upstream_app heimdall;
#        set $upstream_port 443;
#        set $upstream_proto https;
#        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
# sample reverse proxy config for "heimdall" via subdomain, with Authelia
# Authelia container has to be running in the same user defined bridge network, with container name "authelia", and with 'path: "authelia"' set in its configuration.yml
#server {
#    root /config/www;
#    include /config/nginx/authelia-server.conf;
#    location / {
#        # the next line will enable Authelia along with the included authelia-server.conf in the server block
#        include /config/nginx/authelia-location.conf;
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
proxy_cache_path cache/ keys_zone=auth_cache:10m;
my home assistant docker name is “home-assistant” if it matters
Is your RPI host ip 192.168.1.84 ?
Does an nc -zv 192.168.1.84 8123 work from inside the nginx container?
Yes.
No.
LibreELEC2:~ # docker exec swag nc -zv 192.168.1.84 8123
nc: 192.168.1.84 (192.168.1.84:8123): Host is unreachable
macvlan is surely the culprit.
I don’t see why you need it though.
Just use host networking on nginx, forward from your router to the RPI4 IP, and it should work…
That was my previous setup. Unfortunately, whenever i am connected to VPN, i cant connect to HA remotely
I see numerous reference to the inability of connecting from container to host with a macvlan setup.
There is maybe something fishy with your VPN setup. It shouldn’t cause issue on your 192.168.1.0/24 network…
What VPN is it and what’s the rpi4 route when the VPN is connected?
Im using the openVPN manager from Zomboided (Zomboided) · GitHub . I have tried using cyberghostvpn and NordVPN. both have the same result.
Apparently that is the expected result. See Using Nginx with VPN - Add-on Support - LibreELEC Forum .
Did some further reading and this seems to be the case. I have to figure out a different setup to make all this play together nicely
