If you are using any sonoff switches with the built in MQTT broker in Home Assistant, you would notice that power states are not tracked properly after Home Assistant is restarted.
Any switch that is on will be marked as off in Home Assistant until you toggle the switch.
Sonoffs do send telemetry MQTT messages with their current state, but Home Assistant ignores them.
Since I’m already using Node-Red for automations, the below code will reformat these telemetry MQTT messages and keep the power state up to date – Within a few minutes of any Home Assistant restart, the correct power state will be reflected.
Also this gets away from having to run Mosquitto as a MQTT broker and deal with the retain flag all together – having some messages retained can lead to weird results if the cmnd MQTT messages get replayed.
Here is the flow in Node Red:
[{"id":"19d621f6.09260e","type":"comment","z":"8bb76918.ef6b48","name":"Convert MQTT Telemetry Messages to State","info":"","x":190,"y":2320,"wires":[]},{"id":"33aa3552.76201a","type":"mqtt in","z":"8bb76918.ef6b48","name":"All MQTT Messages","topic":"#","qos":"1","broker":"4238db6e.227ed4","x":110,"y":2360,"wires":[["69bba69f.48a888"]]},{"id":"69bba69f.48a888","type":"function","z":"8bb76918.ef6b48","name":"Reformat telemetry to state","func":"tele_check = /^tele/;\npower_check = /POWER/g;\n\nif (tele_check.test(msg.topic) && power_check.test(msg.payload)) {\n new_payload = msg.payload.replace(/.*POWER..\\\"([A-Z]+)\\\".*/, '$1');\n msg.payload = new_payload;\n\n new_topic = msg.topic.replace(/(\\w+).(\\w+).(\\w+)/, 'stat/$2/POWER');\n msg.topic = new_topic;\n \n msg.altered = 1;\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":2360,"wires":[["cd96ee57.d5f1f"]]},{"id":"cd96ee57.d5f1f","type":"switch","z":"8bb76918.ef6b48","name":"If message reformatted","property":"altered","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","outputs":1,"x":690,"y":2360,"wires":[["34dbbf1a.b7301"]]},{"id":"34dbbf1a.b7301","type":"mqtt out","z":"8bb76918.ef6b48","name":"Inject altered message","topic":"","qos":"","retain":"","broker":"4238db6e.227ed4","x":980,"y":2360,"wires":[]},{"id":"4238db6e.227ed4","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"node-red","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
