Hi all, this is my first topic.
I’m trying to control my toshiba air conditioner using IntesisBox TO-RC-MBS-1 adapter it able to convert toshiba bus into a standard modbus RTU.
Disclaimer first, I haven’t used modbus with HA.
I do have a intesisbox to WiFi and this topic came up on my searches.
After some quick searching I would start by trying to use the modbus integration to get the hub connected. Then create sensors and switches for your aircon.
You could then try creating a specific climate component using MQTT climate component as there isn’t a template climate component.
Another way might be to use nodered to send the modbus to MQTT.
Hi all, thank you for your reply, now I can control my AC through the use of simple components such has modbus sensors and modbus switch. I don’t really need the thermostat function, I’m looking for a good UI for control the unit, so switching between various operating mode and change the speed
