Getting Started with Dashboard
So I’ve never used ESPhome and it looks like it might offer a feature I’ve been looking to implement on my mqtt controlled lights that are currently running tasmota.
I fired up an esphome docker and connected to the Dashboard. I was prompted to great my first node.
Going through the process I noticed that there isn’t any lights, or switches, or plugs… Just ESP 8266 and ESP32 boards. Is that expected?
So I picked 8266 generic and used the wizard to great a .yaml file that when I look at it doesn’t seem to have much of anything in it.
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "Home-SSID"
  password: "PassW0rd"
  ap:
    ssid: "Merkury White Lights"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
Is there a guide on how to use the Dashboard?
Does anyone has an example of a basic white light that can be dimmed? I’ve a very visual learner and the chopped incomplete examples on the esphome website is very confusing to me.
Did you look at any of the diy samples? https://esphome.io/guides/diy.html
Light documentation is here:
