Getting started with MCP servers
First you need an mcp server that supports remote connection. There is no standard way to do that but usually you’re running some kind of container that has your ‘server’ in it that server / service will have a way to connect and needs to support SSE for remote connections so the HA MCP client can even connect. From there it’s usually OAuth.
Cloud flare has a blog article of I can locate it.
Now as you can see I’m painting a very self-host or BYO service picture… Are you really looking specifically to use MCP (it’s hard right now and may not be what you are actually looking for)
Or are you trying to add capability to your llm because - if its that you should learn how HA uses tools before throwing MCP on the mix.
Don’t get me wrong MCP is awesome. Just it’s not end-all. There are different methods and your end game dictates the path. The limits of the system dictate what paths are available.
You have a lot of prompt and context to get through before dealing with MCP…
See Friday’s Party for details if youre interested…
