Getting started with WLED
Yes they say DIY with LED’s is much less expensive. But it does add up and it’s not as easy as people say it is. I have been doing HA for a couple of years now and have learned alot from these forums so this is a way of giving back I suppose. Also this is my way of keeping a record of what I bought in case I want to do this again - this is just for a simple beginning setup with two LED strips…
Use case:
Very dark basement stairs that were just painted - in a color that is too dark! Even though the surrounding area is well lit, still not enough lighting on the darkly painted stairs. Decided to put LED strips under the railings, one on each side. Followed these instructions (the wiring in the instructions is spot on):
Be sure to connect everything BEFORE mounting the led strips - easier to troubleshoot and make sure they are working before mounting!
And bought the equipment here (you have to make sure they are the same voltage, the power supply can supply enough but not too much juice, you do that by adding up the number of LED’s , there are plenty of videos available on how to do the calculations but this set togther works well):
Two of these (on ebay). Note do not bother using the power injector leads (as mentioned in the video) and only connect the power supply into the end of the lights at the outside end of the spool. (Connecting it to the other end of the led strip wil not cause any damage but won’t work either.) These already have adhesive on one side of the strip which is very handy. I bought the internal (non-waterproof) version of these.
I have one power supply powering two of the above sets of lights (15a model) - from Amazon. This is only adequate I believe for a simple setup. I leave the power supply turned on so the ESP8266 units are always connecte d via WiFi and ready to turn on at a moment’s notice through HA automation (shown at bottom)):
These are handy instead of cutting the power supply cable (Amazon):
A decent length of three-strand cable (decent thickness to not add too much resistance) - Amazon:
And connectors as I am lazy (Amazon): - note the phot under the railing at the end of the LED strip. Note the wires above are ever so slightly too thick to fit into one end of each of these connectors, but a tiny amount of sanding makes the insulation on the wire thin enough to fit into the connector:
I cannot believe these are so inexpensive (I used two) - Amazon!
And I didn’t like the circuit boards just sitting there uncovered - so I was very pleased with these (photos below) - Aliexpress:
Front:
Back:
And an example of one of the LED’s in action, bottom of stair railings (unfinished basement):
Not sure if I am interested in doing any more LED lights - but these were easy to add into home assistant with the WLED integration, these now turn on with specified settings from home assistant using automations to turn them on when there is motion (if motoin at the top of stairs , lights move downward for two minutes before turning off, if motion at bottom of stairs, lights move upward for two minutes before turning off). Playing with the colors was fun - but makes the stairs more dangerous for older folks! - I have them just white (but moving):
I agree that if you build your own ESP (and yes, you did write DIY) then it is not as simple.
I am technically ESPXYZ-able but still acquired a WLED pre-flashed athom controller and 5m 300LED for 35EUR (Ali of course)…plug an play.
EDIT, btw, I love your explanation, very readable and also you ESP casings :slight_smile:
I’m not sure what you mean here…
there are absolutely times when you will need to use those power injection leads at the end of the strip. And if the strip is too long then you might even need to add your own power injection leads by soldering extra wires onto the a couple of the power pads that are provided at each led.
If the strip is very long then the voltage will drop too much and it will affect the brightness and color (as mentioned in the video)
And they actually do work too so I don’t know why you say they don’t.
There are many video’s on Youtube showing the affects of not using power injection for long strips.
Well - yes use the power injector leads if you like - and in my case connecting the other end would not work for the LEDs - maybe they are supposed to work from either end. One thing I noticed, on my led strips there were no arrows, but on the led strips in the video there were -
Thank you!
The arrows only matter for the data lead. For the power connections it only matters which pin is power and which is ground and that should be printed on the strip too.
the power lines are just power rails that connect to each LED in parallel so it doesn’t matter where you feed the power & ground connections to them (from one end, the other end, both ends or somewhere in the middle) as long as the voltage is sufficient at each LED.
The data wire (green) has to be connected at the start of the strip.
No idea why yours wouldn’t work. if you have an ohmmeter you should have basically 0 ohms continuity at the power lines from one end to the other (red to red & white to white).
What is the “NodeMCU LED” on the ESP8266 meant to show in this case? Sometimes it is lit on one of the ESP8266’s, but never the other one. I programmed them both the same way - as far as I can tell (as mentioned in the above instructions). See the below picture to see what I mean. They both function properly - I am just curious - !???
Update: I have noticed in fact they both do light up but at different times. Not an issue, they still work perfectly. Assuming it’s part of their normal operation, just curious
I posted this a while back… I have noticed over time, one tends to stay on most of the time and the other one not so much. How come that is the case if they are programmed wo work exactly the same with with the same settings and they are even using the same power supply? Nobody has any ideas at all?
Hey all, I built a strip using SK6812 works for on off and changing profiles but weirdly the intensity doesn’t seem to change the brightness. Anyone else have that issue?
Anyone knows how to control usermods pins activated within WLED via Hassio? So I have 2 pins active within WLED:
How can I program these PINs via hassio? For example writing an automation using these pins? What entity would I be pointing to?
