I’ve brand new instance of HA, I added Aeotec gen 5 stick and that went well.
[To add: I used Zwave JS integration and Zwave JS addon]
As an experiment I tried adding zooz 4-in-1 sensor, after adding it showed only 2 entities : temperature (which always show 0F) and battery (which always show 100%). Other entities are not shown.
So I’m assuming zooz is not added correctly.
I initiated start exclusion
pressed zooz button twice, it showed node 5 removed successfully (node 5 was number when added at very first time)
Later I tried add node
-> start inclusion
press zooz button twice, this seems to go through. However newly added device/node always has manufacturer and model as unknown
(I waited almost half an hr and also rebooted HA).
How do I debug / fix this? I want to expand zwave network further but for now just trying to get one sensor working before purchasing and setting up more devices.
Log info (after removing, hard reset and trying to add zooz again)
16:20:21.782 CNTRLR starting inclusion process...
16:20:21.806 CNTRLR handling add node request (status = Ready)
16:20:21.806 CNTRLR the controller is now ready to add nodes
16:20:25.019 CNTRLR handling add node request (status = NodeFound)
16:20:25.138 CNTRLR handling add node request (status = Failed)
16:20:25.139 CNTRLR starting the inclusion failed
16:20:25.140 CNTRLR stopping inclusion process...
16:20:25.209 CNTRLR handling add node request (status = Done)
16:20:25.210 CNTRLR done called for 10
16:20:25.211 CNTRLR the inclusion process was stopped
