Example with lights
[{"id":"42555e88.c533a","type":"alexa-home","z":"6cd0b2f8.4bb6fc","conf":"d27fbe6d.50ed4","device":"146768","acknoledge":true,"name":"Lights","topic":"","x":130,"y":960,"wires":[["fcd64f9a.351b6"]]},{"id":"6e346255.e0e61c","type":"delay","z":"6cd0b2f8.4bb6fc","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":320,"y":960,"wires":[["da207139.aa269"]]},{"id":"da207139.aa269","type":"ha-get-entities","z":"6cd0b2f8.4bb6fc","server":"9405c3fe.d0a6c","name":"","rules":[{"property":"entity_id","logic":"starts_with","value":"light.","valueType":"str"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"output_type":"array","output_empty_results":true,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":470,"y":960,"wires":[["3f4e4b3.f7b1bb4"]]},{"id":"3f4e4b3.f7b1bb4","type":"switch","z":"6cd0b2f8.4bb6fc","name":"None?","property":"payload.length","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":610,"y":960,"wires":[["7cc03dd3.d46db4"],["a86471ab.3ccd"]]},{"id":"7cc03dd3.d46db4","type":"debug","z":"6cd0b2f8.4bb6fc","name":"TTS: all lights are off","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":820,"y":940,"wires":[]},{"id":"fcd64f9a.351b6","type":"switch","z":"6cd0b2f8.4bb6fc","name":"","property":"command","propertyType":"msg","rules":[{"t":"eq","v":"GetLockStateRequest","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":215,"y":960,"wires":[["6e346255.e0e61c"]],"l":false},{"id":"a86471ab.3ccd","type":"split","z":"6cd0b2f8.4bb6fc","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":750,"y":1000,"wires":[["a84aaf67.e8196"]]},{"id":"a84aaf67.e8196","type":"join","z":"6cd0b2f8.4bb6fc","name":"","mode":"custom","build":"string","property":"payload.attributes.friendly_name","propertyType":"msg","key":"topic","joiner":" ,","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":870,"y":1000,"wires":[["98464843.c6d978"]]},{"id":"98464843.c6d978","type":"debug","z":"6cd0b2f8.4bb6fc","name":"TTS: payload.attributes.friendly_name are on","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1110,"y":1000,"wires":[]},{"id":"d27fbe6d.50ed4","type":"alexa-home-conf","username":"Obaldius"},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]
you can even create several devices like “Lights from the first floor” and “Lights from the second floor” and work the messages in Node Red. The advantage of doing it this way is you have flexibility with the questions you can make to Alexa and you needn’t create a routine for every imaginable question, the GetLockState command does the job.
