I picked up some cheap(ish) RBG lamps off of Amazon (https://www.amazon.com/gp/product/B07WGL5L8Q) and am trying to get Tasmota or ESPHome loaded on them. They don’t work with tuya-convert, it looks like they came with the newer firmware that isn’t compatible. I’m seeing the same issue that’s described here: https://github.com/ct-Open-Source/tuya-convert/issues/483
So, it looks I’m going to have to go the hardware flash route. It should be straight-forward, but I’m stuck on one thing – I can’t find a place to pick up ground! There are convenient pads labeled 3.3V, RXD, TXD, and RST, but without tearing the lamp down the rest of the way I haven’t found anything else. My real hope was that the 8-pin connector going to the LED board would work, but I think that is just powering the LEDs (although there has to be a ground connection on there somewhere).
Before I try and tear one of these apart the rest of the way, has anyone either successfully flashed a bulb like it or have any other suggestions?
Here are some pics:
