Getting Telegram webhooks working with Nginx
This post is for those that have a reverse proxy, such as nginx, in front of their Home Assistant and want to get Telegram webhooks working with it. I’m not sure if this is a workaround or a solution, but either way, it works well!
Over the past few days, I’ve been learning how a reverse proxy (in my case, nginx) works. Slowly but surely, I’ve been getting pieces of HA working well behind that proxy. Today’s hurdle was Telegram.
Whenever the webhooks side of Telegram tried to do something, the HA logs would report that access is denied for the IP address of the machine on which I had nginx running. The problem—that (local) IP address is not in the list of trusted_networks for the Telegram component. While tempting, it would not be secure to simply add that address to the list because all requests (including those of nefarious hackers) will be seen as coming from that address!
The way I handled this is to not only add the local IP address of the nginx machine to the trusted_networks in the Telegram component, but ALSO add a location filter to the nginx configuration.
An example entry for your configuration.yaml:
telegram_bot:
  - platform: webhooks
    api_key: YOUR_TELEGRAM_API_KEY
    url: https://YOUR_SUB_DOMAIN.duckdns.org # Or whatever your domain is
    trusted_networks:
      - 149.154.167.197/32 # I don't think these telegram IPs are needed here anymore
      - 149.154.167.198/31
      - 149.154.167.200/29
      - 149.154.167.208/28
      - 149.154.167.224/29
      - 149.154.167.232/31
      - YOUR_NGINX_LOCAL_IP # the pertinent addition
    allowed_chat_ids:
      - YOUR_CHAT_IDS
For your nginx configuration, add this:
location /api/telegram_webhooks {
	proxy_pass http://YOUR_LOCAL_HA_IP_ADDRESS:8123/api/telegram_webhooks;
	proxy_http_version 1.1;
	proxy_set_header Host $host;
	proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
	proxy_set_header Upgrade $http_upgrade;
	proxy_set_header Connection $connection_upgrade;
	allow 149.154.167.197/32;
	allow 149.154.167.198/31;
	allow 149.154.167.200/29;
	allow 149.154.167.208/28;
	allow 149.154.167.224/29;
	allow 149.154.167.232/31;
	deny all;
So, you see, we let nginx take care of allowing only the trusted networks, and we can safely add the local IP address of the nginx machine to the trusted_networks of HA’s configuration.
If anyone knows of a better way to do this or sees something I missed, please feel free to post here. I just got this working now and wanted to share it with any future experimenters.
Hi RiseUp,
could you explain how do you change nginx configuration in Hass.io ?
thank you !!!
Thanks the post. I had been scratching my head for some time before seeing this.
I had all these working without any issue and all of sudden yesterday noticed that it’s stopped working!
After couple hours of troubleshooting found out that Telegram is updating IP range for bots and requests will start coming from different IPs starting July 2019! Hope this will save some time for people.
I had to update allowed IP range in nginx conf to 149.154.167.192/26. Earlier I had same as OP mentioned. While doing this I also added 149.154.160.0/20 and 91.108.4.0/22 as mentioned in the following article. Here is the link to that release notes page:
This explains why my inline keyboard commands stopped working on my caddy hassio instance… Thanks!
Hey guys, how much of this still applies today? Because I have a similar NGINX HTTPS setup in front of a HTTP-HA… and I 've followed all the instructions I can find but I still don’t get my callbacks working.
The sad thing is that I don’t get errors in the logs as well. My telegram bot logs are set to DEBUG and yet all seem ‘fine’.
