Getting the Alias of an automation?
I am trying to do some centralized notifications filtered by different levels (i.e. debug, normal, alarm). for the debug notifications i’d like to pull the alias of the automation that triggered the event to make it more reusable. is there a this object for an automation or something else i can use to grab the alias and pass it on to my notification script?
Pretty sure it is the friendly_name attribute of the automation entity.
Yes, I can see that in the states section of developer tools, but what I am trying to figure out is how do I get the automation entity within the automation itself. I am trying to dynamically get the friendly name of the currently running automation.
I assume from your first post that you are referring to a automation_triggered event. The info is in the event, eg
event_type: automation_triggered
  name: Motion top of stairs off
  entity_id: automation.motion_top_of_stairs_off
  source: state of binary_sensor.motion_top_of_stairs_occupancy
origin: LOCAL
time_fired: "2023-01-11T20:42:14.331986+00:00"
context:
  parent_id: 01GPH93BDS2QCA32SFANNY2R4M
  user_id: null
this.name
Reference: Automation Trigger Variables
i finally found that page as well, thank you!!! problem is i cannot get it to work. the call in the automation looks like this:
service: notify.haapp_sebs_devices
  message: 'Automation name: {{ this.name }}'
but that always returns a blank message.
In theory it should work (because name is a property of the automation’s state object) but, you’re right, I tested it and it failed to work.
Use this (tested and confirmed to work):
this.attributes.friendly_name
That did it! thank you!!!
