Getting the average value from a group of sensors
Hi there,
i am currently evaluating a migration from OpenHab2 to Home Assistant and figuring out how to achieve various things i have done in OH2.
For example:
I have a set of Homematic motion and brightness sensors (HM-Sen-MDIR-O-2), each reporting the brightness as a value from 0-255. I want to compute the average brightness (in percent) from all the sensors. They are entities of a group with ID “group.brightness_sensors”.
  "order": 4,
  "entity_id": [
    "sensor.meqXXXXXX_brightness",
    "sensor.meqYYYYYY_brightness"
Currently, I use a template sensor with a value template to compute and return the average:
platform: template
sensors:
  avg_brightness:
    value_template: '{{ "%.0f" | format((states.sensor.meqXXXXXX_brightness.state | int + states.sensor.meqYYYYYY_brightness.state | int) / 5.12) }}'
    unit_of_measurement: '%'
That way it works currently, but it has two drawbacks:
  • it gets messy, if more sensors are installed
  • it fails on HA restart, as the sensor states may not be available. HA reports
Could not render template avg_brightness, the state is unknown
Is there a more reliable way to compute the something based on the states of grouped entities?
Regards
@m0wlheld
This may interest you…
It definitely does! Thank you.
For the record:
  platform: min_max
  round_digits: 0
  type: mean
  entity_ids:
    - sensor.meqXXXXXX_brightness
    - sensor.meqYYYYYY_brightness
and
  platform: template
  sensors:
    avg_brightness:
      value_template: "{{ '%.0f' | format(states('sensor.brightness_mean') | int / 2.55) }}"
No problem! Hope you enjoy HA as much as I do!
Use the new Statistics Sensor in HA.
