Getting the User Language as set in Profile?
Is there a way to retrieve the language the user has set in their profile? I need to use this in a Config Flow for an Integration. I retrieve other settings from hass.config like latitude and longitude. But I cannot figure out what module to call to get the language.
Did you find a solution to this Bjarne? I need to retrieve the same info.
Unfortunately I did not. I think you need to ask in Discord to get something like this answered. I never got around to it.
I tried, but no answers. :slight_smile:
Will let you know if I find something.
Thanks.
In frontend, there is the hass object available and then you can just call:
hass.selectedLanguage
Thanks. That worked :slight_smile:
I would like to get the selectedLanguage in a template sensor, to choose a language-dependent mapper.
hass.selectedLanguage doesn’t work her.
Does anybody know how to solve this?
template:
  - select:
      - name: "Operation mode (ENG)"
        unique_id: operation_mode_translated_to_english
        state: >
          {% set opt = states('sensor.wolf_cha_0x3_270050_betriebsart_heizgeraet') %}
          {% set mapper = {
            'ODU Test': 'ODU Test',
            'Test': 'Test',
            'Frostschutz HK': 'Frost protection heating',
            'Frostschutz Warmwasser': 'Frost protection hot water',
            'Durchfluss gering': 'Limited flow',
            'Vorwärmung': 'Pre-heating',
            'Abtaubetrieb': 'Defrosting',
            'Antilegionellenfunktion': 'Antilegionalla',
            'Warmwasser': 'Hot water',
            'WW-Nachlauf': 'Hot water caster',
            'Heizbetrieb': 'Heating',
            'HZ-Nachlauf': 'Heating caster',
            'Aktive Kühlung': 'Active cooling',
            'Kaskade': 'Cascade',
            'GLT': 'GLT',
            'Standby': 'Standby',
            'Pump Down': 'Pump down',
            'Nachlauf K': 'Nachlauf K',
            'Undefiniert': 'Undefined',
            'Pool': 'Pool'
          {{ mapper.get(opt) }}
